Takes objects specific layers and change layer size style
cyberflow
Advisor Advisor
cyberflow
Hi there,
First of all i'm a bit new to the lisp language.
I'm actually doing a programming certificat at the university.
So i'm famillior to programming.
Just wanted to put you in context.
I oftenly receive drawings from an external ressource that isn't at standard with my clients.
So each time, i need to take the different elements (Polyline, text and mtext) and put them in the standard of my clients.
With the good layer, style and size.
Been a few years i'm thinking on this lisp and decided this morning to dig into it.
Anyone has a piece of code that changes objects size, layer, style and height to another layer and correct size, height and style ?
Il'l try to make an hybrid lisp out of the one suggested of it.
Or maybe even what i'm looking for exist's too !
Ty !
Btw, after my certificat i'm planning on to specializing into lisp programming so, sooner or later i'm gona do some lisp 🙂
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Kent1Cooper
You could simply Insert [pre-exploded] a little drawing that has one thing of every standard type, and use MATCHPROP to impose the characteristics of those standard elements on the non-standard ones already in the drawing.  Also look at the STANDARDS command.
Kent Cooper, AIA
scot-65
Familiar with programming?
OK.
Do you know your DFX codes?
It will help.
Create a "Class" (vb here) where ENTMOD is the key action.
Make a call to this class with 3 attributes:
DFX to change.
The new DFX value.
The entity itself.
Place this code inside a MNL or any other auto-loading area.
Example:
(GlorifiedChProp 8 "Defpoints" (entget (car (entsel))))
Loop (WHILE..) if using the selection set method.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
