Take the attribute of the dynamic block that appear in the current visibility
S_S_SS
S_S_SS
Hello every one
i need to extract the attribute vale of the dynamic block in the current visibility
then make a new layer with this value and put each block on its layer
I've tried to make something and using lee mac functions about the dynamic block visibility
but it still extract all the attributes on the block
can someone help me about that ??
kindly see the attachment (DWG of an example and Auto lisp file)
Thanks in advance
komondormrex
hey there,
check the following
(defun c:c_vis_att_layer ()
  (if (setq insert_sset (ssget '((0 . "insert") (66 . 1))))
    	(foreach insert (vl-remove-if-not '(lambda (insert) (minusp (vlax-get insert 'isdynamicblock)))
	     			           (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex insert_sset))))
		(if (vl-some '(lambda (dyn_property) (setq dyn_value (vlax-variant-value (vla-get-value dyn_property))) (= "Visibility1" (vla-get-propertyname dyn_property)))
			      (vlax-invoke insert 'getdynamicblockproperties)
		    (entmod (append (entget (vlax-vla-object->ename insert)) (list (cons 8 (getpropertyvalue (vlax-vla-object->ename insert) dyn_value)))))
  (princ)
S_S_SS
Thanks sir
it works correctly
now the dynamic block that i work on it i find more attributes on it in the current visibility
so can we add another feature that it take the value of the attribute in the current visibility and also it's tag contain "lay" ??
I've tried to make this code but it doesn't work
(defun c:c_2 ()
                       '(lambda (insert)
        (if (vl-some
          ;; Modify the block if the condition is met
        ;; Process attributes with "lay" in the tag
        (foreach att (vlax-invoke insert 'getattributes)
          (if (and (eq 'STR (type (vla-get-tagstring att))) ;; Check if it has a tag string
                   (wcmatch (strcase (vla-get-tagstring att)) "*LAY*")) ;; Match tag containing "lay"
            (progn
              ;; Get and display the attribute's value
              (setq att_value (vla-get-textstring att))
              (princ (strcat "\nAttribute with 'lay' in tag found: " att_value))
  (princ)
thanks in advance
komondormrex
check this
(defun c:c_2 ()
                       '(lambda (insert)
        (if (vl-some
          (if (and
		  		   (wcmatch (strcase (vla-get-tagstring att)) "*LAY*") ;; Match tag containing "lay"
				   (minusp (vlax-get att 'visible))
            	(progn
            	  (princ (strcat "\nAttribute with 'lay' in tag found, value: " att_value))
  (princ)
you do not need to check if attributes's tagstring is a string, it is always the string.
S_S_SS
Thanks for that sir
komondormrex
your welcome
