TABLEEXPORT
TABLEEXPORT
Message 1 of 9
TABLEEXPORT
Hi all, is there a way to export multiple tables from autocad drawing  programmatically using lisp or visual lisp? I appreciate any help please.
Solomon
Replies (8)
Message 2 of 9
devitg
Yes, it is possible. And a sample dwg could help .
Message 3 of 9
devitg Thank you so much for your reply.Here I attached a sample drawing. On the drawing there are 11 layouts. On each layout there is one table . I wanted to export all these tables to one folder as .csv files. The file name for these csv tables could be any thing but i prefer if it could be 1.csv, 2.csv, 3.csv and so on just following the layout name where the table is in.
Message 4 of 9
devitg
Find attached te csv s
Message 5 of 9
devitg Thank you so much for your reply. But my question is how could  i could i export multiple tables with a custom command or program, I mean if I have 100 or more layouts how could i export all the tables from each layout at once with a custom command.
Solomon Tessema
Message 6 of 9
devitg
Solomon Tessema, I sent you a private message
Message 7 of 9
PatrickWilkie
Is there a public solution to this issue of programmatically exporting multiple tables?
Or is it SECRET KNOWLEDGE.
What do I have to do to get the great wizard to reveal his incantations to me?
Message 8 of 9
devitg
@PatrickWilkie  it has been a lot time since my last post
For better understanding, and maybe get further help, please upload such sample.dwg ,and a  table.csv as need
Or send it to devitg@gmail.com
Message 9 of 9
Sea-Haven
Like devitg.
1st yes I wrote a export any table direct to excel. Its a super simple version with no bells and whistles.
2nd if I was to loop it for all layouts, can the tables be written to 1 excel worksheet or do you want 1 excel but multiple worksheets. Or each in a seperate Excel ??
3rd this is becoming a custom request so maybe a donation is in order.
; simple table to excel
; expects Title header and data
; BY Alanh Jan 2022
; do not have excel open
; BY Alanh Jan 2022
(defun c:tab2excel ( /  x y z AH:putcell Ah:opennew number2alpha obj cols row)
(defun AH:putcell (cellname val1 / )
(setq myRange (vlax-get-property  (vlax-get-property myxl "ActiveSheet") "Range" cellname))
(vlax-put-property myRange 'Value2 val1)
(defun AH:opennew ( /  )
(if (= (setq myxl (vlax-get-object "Excel.Application") ) nil)
(setq myxl (vlax-get-or-create-object "excel.Application"))
(vla-put-visible myXL :vlax-true)
(vlax-put-property myxl 'ScreenUpdating :vlax-true)
(vlax-put-property myXL 'DisplayAlerts :vlax-true)
; Number2Alpha - Converts Number into Alpha string
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
;   Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC"
(defun Number2Alpha (Num# / Val#)
  (if (< Num# 27)
    (chr (+ 64 Num#))
    (if (= 0 (setq Val# (rem Num# 26)))
      (strcat (Number2Alpha (1- (/ Num# 26))) "Z")
      (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
);defun Number2Alpha
(AH:opennew)
(vlax-invoke-method (vlax-get-property myXL 'WorkBooks) 'Add)
(setq obj (vlax-ename->vla-object (car  (entsel "Pick table "))))
(setq cols (vla-get-columns obj))
(setq rows (vla-get-rows obj))
(alert (strcat (rtos rows 2 0) " rows " (rtos cols 2 0) " columns \n will now send to excel "))
(AH:putcell "A1" (vla-getText Obj 0 0 ))
(setq x 1 y 1 z 2)
(repeat cols
(AH:putcell (strcat (Number2Alpha x) (rtos z 2 0)) (vla-getText Obj y (- x 1)  ))
(setq x (1+ x))
(setq y 2 )
(repeat (- rows 2)
(setq x 1 )
(repeat cols
(setq x (1+ x) )
(setq y (1+ y) )
(vlax-release-object myXL)
(alert "Please save the excel and close if you want to import another table ")
(princ)
(c:tab2excel)
