TABLE FUNCTION
TABLE FUNCTION
grobnik
TABLE FUNCTION
grobnik
Hi to everybody,
I'm asking a question to this forum about table function.
I'm searching a function like EXCEL IF, I mean:
- I have a table with 3 cells, the first contain a calculation value (numeric), the second contain a comparison value, in the third should contain a word "TRUE" or "FALSE" if calculated value is greater or lower than comparison value.
Is there a standard autocad function able to do this ?
I have a lot of drawings containg data.
devitg
@grobnik Please upload your sample.dwg
calderg1000
Regards @grobnik
Try this code, Read the table data from row number 2.
;;;___
(defun c:Val_Tab (/ table nrows vals row column tx1 tx2)
  (setq
    table (vlax-ename->vla-object (car (entsel)))
    nrows (vlax-get-property table 'rows)
    row	  1
  (repeat (1- nrows)
    (setq column 0
	  tx1	 (vlax-invoke-method table 'GetText row column)
	  tx2	 (vlax-invoke-method table 'GetText row (1+ column))
    (if	(> (atof tx1) (atof tx2))
  	    (vla-settext table row (+ 2 column) "TRUE")
        (vla-settext table row (+ 2 column) "FALSE")
    (setq row (1+ row))
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Sea-Haven
As the If is only a true or false no need for progn, (if (>, like me thinking to far ahead some times.
calderg1000
It's true, he corrected himself. Thank you so much
Carlos Calderon G
Sea-Haven
OOps
    (setq row (1+ row))
should be
    (setq row (1+ row))
