System Variable for Publish Option
In Autocad 2016, the  Publish command defaults to  "Include Model When Adding Sheets."  I am trying to find the system variable that contorls this setting so I can turn it off globally for 40 users.
jdiala
I don't know of any variable that control this settings but it is stored on the registry under
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\<<xxx>>\Dialogs\AcPublishDlg\IncludeLayout
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\<<xxx>>\Dialogs\AcPublishDlg\IncludeModel
Set the value of IncludeLayout to "1" and "0" to IncludeModel = layout only
xx.x = Acad version
xxxx:xxx = Product id:Language
<<xxx>> = Profile name
Use the vl-registry-write function to modify the keys
Below is the link is a reference for product Id and language code
http://adndevblog.typepad.com/autocad/2013/08/registry-values-for-productid-and-localeid-for-autocad...
That'll do!  Thanks!
