Switch Backgroundcolor
C.Utzinger
C.Utzinger
Hi
I have this wonderful code for switching the Backgroundcolor between black and grey:
(defun c:SWITCH_BACKCOLOR ( /); ANZEIGE )
  (vl-load-com)
  (setq Anzeige(vla-get-Display(vla-get-Preferences(vla-get-application(vlax-get-acad-object)))))
  (if (= (vlax-variant-value(vlax-variant-change-type(vla-get-GraphicsWinModelBackgrndColor ANZEIGE) vlax-vbLong))0)
    (progn
      (vla-put-GraphicsWinModelBackgrndColor ANZEIGE 6710886)
      (princ "\nHintergrund Modellbereich auf -grau- gesetzt")
    (progn
      (vla-put-GraphicsWinModelBackgrndColor ANZEIGE 0)
      (princ "\nHintergrund Modellbereich auf -schwarz- gesetzt")
  (princ)
But i'm looking for a code witch saves the original Color (for example blue) and turns back to this after i finish witch the grey one.
Please help...
ВeekeeCZ
It depends.
Most simple solution could be like this.
(vl-load-com)
(defun c:SWITCH_BACKCOLOR  (/ ANZEIGE cbc)
  (setq Anzeige (vla-get-Display
                    (vla-get-application (vlax-get-acad-object))))
        cbc (vlax-variant-value
                vlax-vbLong)))
  (if (or (not *switch_backcolor-original*)
          (= *switch_backcolor-original* cbc)
    (progn
      (setq *switch_backcolor-original* cbc)
      (princ "\nHintergrund Modellbereich auf -grau- gesetzt"))
    (progn
      (vla-put-GraphicsWinModelBackgrndColor ANZEIGE *switch_backcolor-original*)
      (princ "\nHintergrund Modellbereich auf -ORIGINAL- gesetzt")))
  (princ)
But. If the user turns off AutoCAD with temp color on, then the original color is lost.
... solution I can imagine is that we can export the original number to *.txt file. This will be exported once when the file does not exist and when the current color is different than exported original or your temp color (meaning in case that user changed the setting on purpose)
Then you need to add one line to ACADDOC.lsp to reset a background on start up.
Or... someone else will figure out something easier.
C.Utzinger
HI
The first Option is enough for me. Thank you!!!
Kind Regards
Christian
