Visual LISP, AutoLISP and General Customization
superflatten lisp
16 REPLIES 16
Message 1 of 17
dvir860
8724 Views, 16 Replies
superflatten lisp
I have a lip that flattens the drawing to z=0.
I want the Lisp to be set to run automatically on all drawing (without having to manually select elements) and not to open a SuperFlatten options dialog.
What do I need to change or add to the code to do this?
16 REPLIES 16
Message 2 of 17
pendean
in reply to: dvir860
Google Search offers lots of answers including this one http://www.lee-mac.com/autoloading.html
Message 3 of 17
dvir860
in reply to: pendean
The link you have attached shows how to load lisps and this I know how. I asked about editing the code.
Message 4 of 17
ronjonp
Download the latest version HERE. Not sure if there is a command line call though.
Message 5 of 17
dvir860
I didn't found solution to my problem. Is anybody know what I need to change in the code that it will solve my problem?
Message 6 of 17
dlanorh
It would be pointless altering the superflatten code to do what you want. Try this snippet.
(defun rh:saeou (o / lst)
  (setq lst (list (list 0.0 0.0 0.0) (list 0.0 0.0 1.0e99) (list 0.0 0.0 1.0e-99) (list 0.0 0.0 0.0)))
  (while (> (length lst) 1)
    (vlax-invoke o 'move (car lst) (cadr lst))
    (setq lst (cdr lst))
  );end_while
);end_defun
(vl-load-com)
(defun c:flatdwg ( / ss cnt)
  (setq ss (ssget "_X"))
  (cond (ss
          (princ "Flattening Drawing. Please Wait.")
          (repeat (setq cnt (sslength ss))
            (rh:saeou (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))))
          );end_repeat
        (t (alert "Nothing Found"))
  );end_cond
  (princ)
);end_defun
(c:flatdwg)
(princ)
It should run when loaded.
See HERE for options on how/where to place it.
I am not one of the robots you're looking for
Message 7 of 17
dvir860
in reply to: dlanorh
Your lisp isn't flat elements that into blocks.
Message 8 of 17
diagodose2009
You make a demo.Avi  .
Can you test this programe flatthen.lsp with many capture-picture BeforeXX.Jpg and AfterXX.JPg..? I need a demo Video , . You put this Video to youtube.com/your-account
Message 9 of 17
dlanorh
What type of blocks? xrefs? dynamic? static?
Message 10 of 17
dvir860
I meant that your lisp is not the same as mine because the lisp does indeed surface elements to Z = 0 but does not surface elements within the blocks so it does not help me what you attached.
I'ne interested in using my lisp but without having to manually select elements and not to open a SuperFlatten options dialog.
Message 11 of 17
dlanorh
And my question was in what type of blocks do you want the elements flattened, bearing in mind that flattening 3d dynamic blocks will probably break them.
Message 12 of 17
john.uhden
Try this one adapted from an oldie of mine...
(defun c:FlattenAll ( / *error* vars vals @flatten cmd ss i n e0 e ent etyp fixed)
   ;*         FlattenAll.LSP by John F. Uhden                                   *
   ;*                           2 Village Road                                  *
   ;*                           Sea Girt, NJ  08750                             *
   ;; Changes the Z value or 38 code to 0.0 for all  objects, including
   ;; their subentities such as heavy vertices and attributes.
   ;; Locked layer checking removed.
   ; v1.0 (8-27-99)
   ; v15.00 (04-07-00) for R15
   (gc)
   (vl-load-com)
   (princ "FlattenAll (c)1999-2020, John F. Uhden\n")
   (princ "Adapted from Z0.lsp (c)1999-2000\n")
   (defun *error* (error)
     (mapcar 'setvar vars vals)
     (vla-endundomark *doc*)
     (cond
       ((not error))
       ((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
       (1 (princ (strcat "\nERROR: " error)))
     (princ)
   (setq vars '(cmdecho))
   (setq vals (mapcar 'getvar vars))
   (or *acad* (setq *acad* (vlax-get-acad-object)))
   (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
   (vla-startundomark *doc*)
   (mapcar 'setvar vars '(0))
   (command "_.expert" (getvar "expert")) ;; dummy command
   ;; Function to dig into each entity or subentity and change either its
   ;; 10, 11, 12, 13, or 38 code to 0.0:
   (defun @flatten (ent / new)
      (foreach item ent
         (cond
            ((and (= (car item) 38)(/= (cdr item) 0.0))
               (setq new (cons 38 0.0)
                     ent (subst new item ent)
            ((and (/= etyp "LWPOLYLINE")(vl-position (car item) '(10 11 12 13))
                  (not (atom (cdr item)))
                  (> (length item) 3)
                  (/= (last item) 0.0))
               (setq new (reverse (cons 0.0 (cdr (reverse item))))
      (setq fixed (or fixed new))
      (if new (entmod ent))
   (setq i 0 N 0)
   (vlax-for block (vlax-get *doc* 'blocks)
     (vlax-for obj block
        (prompt (strcat "\rProcessing # " (rtos (1+ i) 2 0)))
        (setq e0 (vlax-vla-object->ename obj)
                   e  e0
                   ent (entget e)
                   etyp (cdr (assoc 0 ent))
                   fixed nil
                   i (1+ i)
        (if (assoc 66 ent)
           (while (/= (cdr (assoc 0 ent)) "SEQEND")
              (@flatten ent)
              (setq e (entnext e) ent (entget e))
           (@flatten ent)
        (if fixed
           (progn
              (entupd e0)
              (setq n (1+ n))
   (prompt (strcat "\nChanged " (rtos n 2 0) " objects to elevation 0."))
   (*error* nil)
(defun c:FA ()(c:FlattenAll))
John F. Uhden
Message 13 of 17
john.uhden
in reply to: john.uhden
I didn't like the name, so it is now SQUASH.
(defun c:SQUASH ( / *error* vars vals @Anonymous ss i n e0 e ent etyp squashed)
   ;*         SQUASH.LSP   by John F. Uhden                      *
   ;*                                             2 Village Road                      *
   ; v1.0 (8-27-99)
   ; v??.0  (8-31-2020) renamed from FlattenAll.lsp
   (gc)
   (vl-load-com)
   (princ "Squash (c)1999-2020, John F. Uhden\n")
     (cond
       ((not error))
     (princ)
   (defun @Anonymous (ent / new)
      (foreach item ent
         (cond
                  (> (length item) 3)
      (setq squashed (or squashed new))
   (setq i 0 N 0)
     (vlax-for obj block
                   e  e0
                   ent (entget e)
                   squashed nil
                   i (1+ i)
        (if (assoc 66 ent)
              (@squash ent)
           (@squash ent)
        (if squashed
           (progn
              (entupd e0)
              (setq n (1+ n))
   (prompt (strcat "\nSquashed " (rtos n 2 0) " objects to elevation 0."))
   (*error* nil)
(defun c:SQ ()(c:Squash))
John F. Uhden
Message 14 of 17
Thank you very much John
Message 15 of 17
hi, in my case i neet to keep the blocks but in some case the block is exploded,  I'll shere the picture and dwg. Can you help me?
Message 16 of 17
@silvestresallesjunior4 ,
Have you tried my SQUASH program?  It can easily be made to run automatically on start-up with every drawing.  No user input is required.
John F. Uhden
Message 17 of 17
bhoomika66Q5H
TOTALLY WORKED FOR ME
AutoCAD Inside the Factory
