Substr
Substr
andreas7ZYXQ
Substr
andreas7ZYXQ
I have a issue id like to solve.
In my substr i want to replace 16 with with pos..
i dont know how to get around it and make it work..
thanks.
(defun c:001 ()
 (setq plan "1");
 (setq pos "2")
 (setq name (getvar "dwgname"))
 (setq pos2 (substr name 16 1))
;(setq pos2 (substr name pos 1)) <---- someone that could give me some help and explain why it wint work? (if (= plan pos2) (princ "This is true") (princ "This is false") );end of if statement );defun
ВeekeeCZ
your pos variable must be an INTEGER not a STRING
(setq pos 2)
then for your father comparison must be plan an integer as well
(defun c:001 ()
 (setq plan 1);
 (setq pos 2)
 (if (= plan pos2)
 );defun
Read HERE about integers, real, strings... and conversions between them...
john.uhden
How can (= plan pos2) ever be true?
plan is an integer, but pos2 is a string.
John F. Uhden
ВeekeeCZ
Good point. Thx
@andreas7ZYXQ Then keep your plan a string.
andreas7ZYXQ
I changed to this. Thanks alot for the advice @ВeekeeCZ
(defun c:001 ()
 (setq plan "1");
 (setq pos "2")
(setq pos2 (substr name (atoi pos) 1))
 (if (= plan pos2)
 );defun
