Substitution blank for space
mmitchellH6TRW
Message 1 of 8
mmitchellH6TRW
I am trying to replace string " " with "" : delete all spaces in the string.
(setq
cable_count "1-7XD;\\P 1608AA,156;\\P 1608AA,P0156:7-8;11-12XD;\\P 1608AA,P0156:S7,1-3;\\P16-24XD"
cable_count (vl-string-subst "" " " cable_count)
Replies (7)
Message 2 of 8
paullimapa
vl-string-subst only will replace the first instance so use vl-string-translate instead
Also your string value though all looks like spaces they may not be
so I manually deleted the space and then used space bar on the cable_count and then this works:
(setq
cable_count (vl-string-translate " " "-" cable_count)
Paul Li
IT Specialist
@The Office
Message 3 of 8
komondormrex
could be done with to list and back converting
(setq cable_count "1-7XD;\\P 1608AA,156;\\P 1608AA,P0156:7-8;11-12XD;\\P 1608AA,P0156:S7,1-3;\\P16-24XD"
	  cable_count (vl-list->string (vl-remove 32 (vl-string->list cable_count)))
Message 4 of 8
mmitchellH6TRW
Thank you for your insight:
      cable_count (vl-string-translate " " "" cable_count)
Does not work, (I need the the spaces eliminated, not replaced.) and my version of your code fails.
Is there a nil character that I can replace it with?
Message 5 of 8
mmitchellH6TRW
Thank you. This works.
Message 6 of 8
mmitchellH6TRW
Unfortunately, when implemented, pasting the text without spaces back into the multiline attribute, it replaced the \\P with <carriage return> <space>. I don't think it is fixable with lisp.
Still any ideas would be appreciated.
Problem in whole:
How to delete all spaces out of a multiline attribute, in all inserts of a block, programmatically.
Message 7 of 8
komondormrex
could you show how do you perform pasting back a spacefree string to multiline attribute? i have modeled the situation and it worked just fine.
Message 8 of 8
mmitchellH6TRW
;;  (replacetagvalue tag newvalue ent)
;; tag - the attribute name
;; newvalue - the new value for that attribute
;; ent - the ent name of the entity
;; returns T if change is made
;; else returns nil
(defun replacetagvalue (tag newvalue ent / elist)
  (if (and (assoc 66 (setq elist (entget ent))))
    (progn
      (setq ent   (entnext ent)
            elist (entget ent)
      (while
        (not
          (or
            (= (cdr (assoc 0 elist)) "SEQEND")
            (= (cdr (assoc 2 elist)) tag)
              elist (entget ent)
  (if (= (cdr (assoc 0 elist)) "SEQEND")
    nil
    (progn (setq elist (entget ent))
           (setq elist (subst (cons 1 newvalue) (assoc 1 elist) elist))
           (entmod elist)
           T
;;  (gettagvalue tag ent)
;; returns attribute value if not ""
;; else returns nil
(defun gettagvalue (tag ent / elist)
    (progn
            elist (entget ent)
      (while
        (not
          (or
              elist (entget ent)
    nil
    (progn
            elist (reverse elist)
      (cdr (assoc 1 elist))
;; DCS to Delete Cable block Spaces		Didn't get this to work
(defun c:DCS (/ fiber_cable_ss i cable_count)
  (setq fiber_cable_ss (ssget "_X" '((2 . "FIBER_CABLE"))))
  (sssetfirst nil fiber_cable_ss)
  (repeat (setq i (sslength fiber_cable_ss))
    (if
      (setq cable_count (gettagvalue
                          "CABLE_COUNT"
                          (ssname fiber_cable_ss (setq i (1- i)))
      (progn
        (setq cable_count (vl-list->string
        (replacetagvalue "CABLE_COUNT" cable_count (ssname fiber_cable_ss i))
  (setq fiber_cable_ss nil)
  (princ)
(princ "\nDCS to Delete Cable block Spaces")
FIBER_CABLE is a block with among other data attributes CABLE_COUNT.
a default for CABLE_COUNT was "1-7XD;\\P 1608AA,156;\\P 1608AA,P0156:7-8;11-12XD;\\P 1608AA,P0156:S7,1-3;\\P16-24XD"
For some reason our ACAD to GIS conversation tool was having trouble with the spaces (and perhaps the \P) but when the spaces were deleted it was fine. I delete the spaces out of the block and the sample inserts in the template. And was trying to write a lisp to process previous production work.
Since then the spaces have "reappeared" in work that my drafters had cleaned of spaces.
I am thinking now that it is a function of multiline attributes.
This DCS is just as simple as choose a FIBER_CABLE block. Select similar. Find [Find " "] [Replace ""] <replace all>.
