String Replace Between Closing Parenthesis and Forward Slash
DGCSCAD
Message 1 of 10
DGCSCAD
How would I add a space (or any character) between ) and \ in a string?
Example:
String: "(test)\\p"
Result: "(test) \\p"
I'm stumped.
AutoCad 2018 (full)
Win 11 Pro
Replies (9)
Message 2 of 10
paullimapa
Since Autolisp uses the slash as an escape code you would have to double it for it to find a match. So try searching for following:
here’s a link to give you some ideas on what functions to try to do a search and replace
Paul Li
IT Specialist
@The Office
Message 3 of 10
ec-cad
(setq a "(test)\\p")
(setq b (substr a 1 (- (strlen a) 2)))
(setq add " "); what to add
(setq new (strcat b add "\\p"))
ECCAD
Message 4 of 10
DGCSCAD
@paullimapa
(setq txt "(test)\\p")
(wcmatch "*)\\\\*" txt)
nil
wcmatch is a fickle beast.
@ec-cad
That does work under those exact conditions, but I'm needing to find and replace many occurrences, with variances in string length between the parenthesis, which I failed to mention. My apologies.
AutoCad 2018 (full)
Win 11 Pro
Message 5 of 10
paullimapa
you incorrectly used the wcmatch function...this is the correct format:
(wcmatch txt "*)\\*")
Returns: T
(setq txt "(test)\\\\p")
(wcmatch txt "*)\\\\*")
Returns: T
look it up here:
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-EC257AF7-72D4-4B38-99B6-9B09952A53AD
Paul Li
IT Specialist
@The Office
Message 6 of 10
DGCSCAD
@paullimapa
In my haste, yes I did. My apologies. I need to step back for a minute.
AutoCad 2018 (full)
Win 11 Pro
Message 7 of 10
paullimapa
not a problem..I get the formatting of wcmatch confused all the time as well.
Paul Li
IT Specialist
@The Office
Message 8 of 10
MrJSmith
Few things.....
  1.  I am confused as to why you were using wcmatch when you wanted to replace the string.
  2. You used wcmatch incorrectly, it should be string patter, not pattern string.
    1. (wcmatch txt "*)\\*") => T
  3. Your example suggests this is coming from MTEXT inside AutoCAD? In which case, it would only be "\\" to get the text to replace.
    1. If you are selecting some MTEXT in AutoCAD:
(defun replaceAll (oldtext newtext textstring / i n)
	(setq n (strlen newtext))
	(while (setq i (vl-string-search oldtext textstring i))
		(setq
		textstring (vl-string-subst newtext oldtext textstring i)
		i (+ i n))
	textstring
(replaceAll ")\\P" ") \\P" (cdr (assoc 1 (entget (ssname (ssget) 0))))
  • If you are NOT selecting MTEXT:
(replaceAll ")\\p" ") \\p" txt)​
Message 9 of 10
ronjonp
@DGCSCAD Try this:
(vl-string-subst ") \\p" ")\\p" "(test)\\p")
Message 10 of 10
ec-cad
I have a 'partial' solution. See attached .dwg for details.
Does all correctly except those \\\p in Mtext.
Feel free to grab and modify (uses old lisp, no Vlisp).
;; chgtxt.lsp
;; rev 1.0
;; Search 'old' text, replace with 'new' text in TEXT or MTEXT
;; Local Function to check for Old String / Replace with New String..
(defun s_r ( ostr nstr oldtext )
   (if (and (/= ostr nil)(/= nstr nil)(/= oldtext nil)); old string, new string
     (progn
       (setq os ostr ns nstr n_str "" found 0 si 1)
       (setq osl (strlen os))
       (setq nsl (strlen ns))
       (setq s oldtext); pass in old value
        (while (= osl (setq sl (strlen (setq st (substr s si osl)))))
          (if (= st os)
           (progn
            (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl))))
            (setq found 1); Found old string
            (setq si (+ si nsl))
           ); end progn
          (setq si (1+ si))
          ); end if
         ); end while
        (if (= found 1)(setq n_str s)); modified string
    ); end progn
   ); end if
 (princ)
); end function
;; Function to change matching text strings in Text or Mtext
(defun C:chgtxt (/ oldstring newstring )
 (setq oldstring (getstring 1 "\nOld string to replace = ")); e.g. )\\
 (setq newstring (getstring 1 "\nNew string replacement = ")); e.g. ADDED Something
 (setq ss nil C 0)
 (setq ss (ssget "X" (list (cons 0 "*TEXT"))))
 (if ss
  (progn
   (repeat (sslength ss)
    (setq ent (entget (ssname ss C))); entity list
    (setq otxt (cdr (assoc 1 ent))); just the old text string
    (s_r oldstring newstring otxt)
    (if (= found 1)
      (entmod (setq ent (subst (cons 1 n_str)(cons 1 otxt) ent)))
    ); if
    (setq C (+ C 1))
   ); repeat
  ); progn
 ); if
); function
ECCAD
