String from GETCFG to List for new_dialog - Possible?
scot-65
Advisor Advisor
scot-65
Due to possible R/W permission issues at the user level, I would like to store
a dialog position value using SETCFG.
Initially this will be set to '(-1 -1).
Using GETCFG, the value returned is a string and new_dialog will only accept a list.
How to convert this String "'(-1 -1)" to a List '(-1 -1)?
Thanks in advance.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
hmsilva
Hi Scot,
something like this, perhaps
_$ (cadr (read "'(-1 -1)"))
(-1 -1)
Hope this helps,
Henrique
scot-65
Thank You my friend, it helped.
I also had issue going the other way - recording to, and was able to resolve.
For future searches (and possible Kudos), here are the related parts:
;set a gremlin (session variable) from a call to getcfg so
;as not having to read the configuration file every time.
;place before the call to new_dialog: (if (not USER_LCVD) ;dialog position (if (setq a (getcfg "AppData/LCVD")) (setq USER_LCVD (cadr (read a))) (setq USER_LCVD '(-1 -1)) );if );if
;this snippet will work for both single and
;repeating dialog boxes:
(new_dialog "LayConv" dcl_id "" USER_LCVD)
;record the position of the dialog into the gremlin:
 (action_tile "accept" "(LCV_GET)(setq USER_LCVD (done_dialog 1))")
;and finally, record the gremlin to the configuration file
;(this is set up for a looping dialog):
 (unload_dialog dcl_id)(setq dcl_id nil)
 (setcfg "AppData/LCVD" (vl-princ-to-string USER_LCVD))
Thanks again, Henrique.
Scot-65
hmsilva
You're welcome, Scot.
Glad I could help
Henrique
