Strech dimensions, objects at a specified angle.
Code_x
Code_x
I am looking for a macro that can let me stretch objects at a specific angle.  Sometimes I have dimension strings or objects that needed to be extended to a certain point.  I have been using. y and .x ortho snap with macro.  Is there a macro that can let me pick any specific angle and stretch object points or lines according to the that angle?
This is the video that has the macro set for stretch X and Y ortho direction, very handy.  I am looking for similar macro that can allow me to stretch with the same angle. Anyone knows how to achieve this?
Move in Y
https://knowledge.autodesk.com/community/screencast/27da7f0d-0403-411e-80e7-f058adf439f1
JBerns
@Code_x,
Please provide a sample drawing with "before" and "after" examples.
This will help the community to visualize your goal.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Kent1Cooper
If you're not on Acad LT, you may be able to use AlignSnap.lsp with its AS and ASB commands, available >here<.  Use one of those commands, pick the angled whatever object [anything straight], and the crosshairs will align with it.  Turn ORTHO On, and you can Stretch [or Move or Copy or...] in the direction parallel [or perpendicular] to it.
Kent Cooper, AIA
Code_x
Move in Y
Kent1Cooper
Your link doesn't work for me -- Ctrl+Alt+E has no effect, locking into a specific direction or otherwise, when I try it [Acad2020 here].  So you must have something assigned to that key combination, but we can't tell what it contains from your link.  I would guess it says simply <90 to lock the direction to vertical [it works that way if I put that into a Tool Palette button].  But without a fixed/known direction, maybe this will work for you:
In the Tool Palette button called "test" below, I put this content:
(strcat "<" (angtos (getangle)))
Then I can grab a grip [note the free direction of movement at first], pick on that button, pick two places on something [the angled Line here] to establish the angle, and the stretching direction on that grip is locked into that angle:
It also works within a STRETCH command, when picked after giving it the start point of the displacement.
If you want to just pick once on something to establish the angle, but after selecting the grip you want to move rather than beforehand with my AlignSnap.lsp routine, it's possible that elements of that could be worked into the Tool Palette button's contents, or maybe the Tool Palette could contain a call to a routine like that to get the angle, not in command-definition form but as a function that could be used within grip-editing -- I'd have to think about that....  But if you're willing to pick twice to set the angle, as with that Tool Palette content, you can do that on anything, and the two points don't even need to be on the same object, if your direction might sometimes be [for example] between corners of a sawtooth building outline or something.
Kent Cooper, AIA
Code_x
Hi, is there a way to add this macro button on the mouse right click?
