strcat error
strcat error
alexandre_benekowski
Message 1 of 9
strcat error
Hi, folk,
i´m typing a lisp, but i can´t solve a problem with "strcat":
(defun c:folhas ()
;INSERÇÃO DE DADOS....
(setvar "attdia" 0)
(setq PONTO (getpoint "\nClique no primeiro ponto de inserção "))
(setq PONTO_2 (getpoint "\nClique no segundo ponto de inserção "))
(setq PONTO_3 (getpoint "\nClique na primeira seção da segunda coluna "))
(setq QUANTIDADE_COLUNAS (getint "\nDigite a quantidade de colunas"))
(setq QUANTIDADE_LINHAS (getint "\nDigite a quantidade de seções em cada coluna "))
;CONTAS E CÁLCULOS....
(setq VALOR 1)
(setq QUANTIDADE_SEÇÕES (* QUANTIDADE_COLUNAS QUANTIDADE_LINHAS))
(repeat QUANTIDADE_SEÇÕES
(setq VALOR1 (itoa VALOR))
(setq VALOR_FINAL (strcat VALOR1 " / "))
(setq VALOR_FINAL1 (strcat VALOR_FINAL QUANTIDADE_SEÇÕES))
(command "_insert" "C:/BLOCOS/FOLHAS" ponto "1" "1" "0" VALOR_FINAL1)
(setq valor (1+ valor))
I need to "strcat" number / quantity
thanks!!!!
Accepted solutions (3)
Replies (8)
Message 2 of 9
ВeekeeCZ
You need to convert QUANTIDADE_SEÇÕES from an integer to a string.
Message 3 of 9
stevor
Could be the same as your other string types from integers:
 (setq VALOR_FINAL1
   (strcat VALOR_FINAL (itoa QUANTIDADE_SEÇÕES)) )
S
Message 4 of 9
Hi stevor, the code "(setq VALOR_FINAL1 (strcat VALOR_FINAL (itoa QUANTIDADE_SEÇÕES)) )" worked!!! thank you so much!!!
Message 5 of 9
ronjonp
If you don't want to worry about your data type for strcat you could use a function like so and feed it a list of whatever. Although I'm not sure of the usefulness 🙂
(defun _dpstrcat (l) (apply 'strcat (mapcar 'vl-princ-to-string (mapcar 'eval l))))
(setq i 69.)
(setq e (car (entsel)))
(_dpstrcat '("string" 1 i e))
Message 6 of 9
john.uhden
Obviously not for this purpose...
(_DPSTRCAT (ENTGET (ENTLAST)))
*Cancel*
bad argument type: consp <Entity name: 7e2f5958>
Only teasing
John F. Uhden
Message 7 of 9
ronjonp
*Cancel*
Only teasing
(_dpstrcat '((car (entsel))))
Not sure why I wrote this madness! 😅
Message 8 of 9
john.uhden
@ronjonp wrote, " Not sure why I wrote this madness!"
Just for fun. At least I hope that's why we are here.
Many thanks for improving my day.
John F. Uhden
Message 9 of 9
ronjonp
@john.uhden wrote:
@ronjonpwrote, " Not sure why I wrote this madness!"
Cheers! 🍻
Glad to have improved your day!
