strange error when running the lisp
sam_safinia
Message 1 of 13
sam_safinia
I was running a routine for a while but I receive weired error since yesterday. It look some variable setting has changed which I cannot find it.
After running my lisp, when it comes to this line:
(command ".style" "Standard" "simplex" (* 1.000 1.000) "1" "0" "n" "n" "n")
it pops up text style window and asking to select fonts etc. but previously was automatic and when I close it I get this error:
Command: Standard Unknown command "STANDARD". Press F1 for help.
Command: simplex Unknown command "SIMPLEX". Press F1 for help.
Thanks for your help
Replies (12)
Message 2 of 13
Satoews
(command "-style" "Standard" "simplex" (* 1.000 1.000) "1" "0" "n" "n" "n")
Try this it should suppress the window.
The error your getting is the lisp is trying to use standard and simplex as their own commands instead of part of styles command.
Shawn T
Message 3 of 13
sam_safinia
Then how can i get back it to normal? thanks
Message 4 of 13
Satoews
Try replacing the code you have for the code i posted above.
Shawn T
Message 5 of 13
sam_safinia
Sorry, but I cannot see any difference between two codes.....
Message 6 of 13
Satoews
".style" will not suppress the window "-style" should suppress that window.
Shawn T
Message 7 of 13
sam_safinia
Ok thanks
Message 8 of 13
Satoews
Appologies I was doing that all from my phone, your lisp was getting confused by the window. It paused the lisp while the window is active and restarted again when it was closed. That is why you got the wierd errors. Usually you can suppress that window prompt and run the command off the command line  with a "-yourcommandhere" instead of a "_.yourcommandhere". This will in turn use the rest of the lisp and make your style command automatic again. Hope this is what you were looking for =).
Shawn T
Message 9 of 13
Kent1Cooper
That's not the issue.  That's true for dialog-box command names when typed in at the Command line, but within an AutoLisp (command) function, the dialog box will be suppressed, without the need for the hyphen, unless you precede the (command) function with (initdia) to force the dialog box to be used.  [I don't suppose your code has suddenly acquired an (initdia) function that it didn't have before....]  You can include the hyphen if you want, but it won't be what solves the problem -- something else is going on [perhaps the phone issue mentioned elsewhere?].
The original post describes errors consistent with the .STYLE command name not being recognized, since it would then go on and try to take Standard and Simplex as command names, which would explain the error messages mentioned.  Was there also an unknown-command error message about the Style command?  With the preceding period/decimal, that can't be explained by its merely having been Undefined, so there would seem to be some deeper problem.  When I paste that code into the Command line in Acad2016, it works fine, and without the dialog box coming up.
Kent Cooper, AIA
Message 10 of 13
Satoews
My appologies, kent is correct. I got confused due to some commands not haveing a hyphen ability and my knowledge in script told me to hyphen that command. =P
Shawn T
Message 11 of 13
dbroad
Unless something happened to break AutoCAD so that it does not recognize the style command, your error is probably at an earlier point in the program so that ".style" might be interpreted as an option or entry to the last prompt of a previous command.  I also have no idea why the (* 1.000 1.000) is included in the command.  A simple 1 would do better.  To cancel any pending command, you should be able to use an empty command function.
(command)
(command ".style" ....)
but it would be better to find the problem unless this is the first command statement in the program.
Architect, Registered NC, VA, SC, & GA.
Message 12 of 13
sam_safinia
As Kent says there should be another issue somewhere because it was
supersing the window before. It's in the middle of my code and let you know
guys if I found it. Thanks
Message 13 of 13
sam_safinia
I could not find the variable that has benn changed by mistake. I reset my AutoCAD settings to default and then it solved the issue!
Thanks for the help
