strange behavior from lisp.
So I wrote a lisp routine which turns layers on and off and brings them to the foreground in order, it's a one press button which sets the draworder for our xrefs. The lisp routine is fine, I think, it is as follows -
(defun C:FY (/ BT TP)     ;DEFINES FY TO RUN COMMAND SETS BT AND TP AS LOCAL VARIABLES
 (setq bt (getvar "extmin")    ;SET BT UPPER RIGHT CORNER
       tp (getvar "extmax")    ;SET TP LOWER RIGHT CORNER
 )        ;_  end setq
 (COMMAND "-LAYER" "OFF" "*" "Y" "")  ;TURNS ALL LAYERS OFF.
 (COMMAND "-LAYER" "ON" "S-WALLOV" "")   ;TURNS ON S-WALLOV
 (COMMAND "_DRAWORDER" "W" BT TP "" "F" "") ;SETS THE DRAW ORDER FOR S-WALLOV ON TOP.
 (COMMAND "-LAYER" "ON" "S-WALLUN" "")   ;TURNS ON S-WALLUN
 (COMMAND "_DRAWORDER" "W" BT TP "" "F" "") ;SETS THE DRAW ORDER FOR S-WALLUN ON TOP.
 (COMMAND "-LAYER" "ON" "*" "")   ;TURNS ALL LAYERS ON.
 (COMMAND "-LAYER" "ON" "S-MARKING" "")   ;TURNS ON S-MARKING
 (COMMAND "_DRAWORDER" "W" BT TP "" "F" "") ;SETS THE DRAW ORDER FOR S-MARKING ON TOP.
 (COMMAND "-LAYER" "ON" "*HATCH*" "")   ;TURNS ON HATCH
 (COMMAND "_DRAWORDER" "W" BT TP "" "B" "") ;SETS THE DRAW ORDER FOR ALL HATCH ON BACK.
 (COMMAND "_REGENALL")    ;REGENS VIEW
 (PRINC)      ;ENDS
could probably be better but its the first routine ive written. Anyway the problem comes when I use my macro, I have this lisp in my startup suite so it loads on autocad startup, but when I press my button macro it seems to add in a right click on every line of the lisp routine, but if I type fy in the command line it runs perfectly. The problem occurs when I use the macro to run the lisp routine.
The macro is simply -
^C^C(C:FY)
any suggestions?
Kent1Cooper
@Anonymous wrote:
... when I press my button macro it seems to add in a right click on every line of the lisp routine, but if I type fy in the command line it runs perfectly. ....
I don't see anything obvious.  What's the indication that it's "add[ing] in a right click on every line"?  Can you post a command-line history when you run it from the macro?
[There's a way to find everything on a given Layer without turning all others off, which could shorten this considerably, but we can get into that later....]
Kent Cooper, AIA
paullimapa
Would there be a difference if you change the macro to:
^C^CFY;
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
cadffm
Please tell me in which version the draworder command an extra enter after your FRONT input, thx
"_DRAWORDER" "W" BT TP "" "F" "" < this "" last enter.
Can anybody give me the textscr log sequence/part
Sebastian
Kent1Cooper
@cadffm wrote:
.... an extra enter after your FRONT input....
That's the should-have-been-obvious-to-me answer, I'll bet!  [But I haven't tested it.]
Kent Cooper, AIA
Kent1Cooper
@Kent1Cooper wrote:
.... There's a way to find everything on a given Layer without turning all others off, which could shorten this considerably....
That's by way of (ssget) searching the entire drawing, filtering by Layer.  Not only does it avoid the Layer isolations, but there's no need for Zooming, or any variables, and you can do as many commands in one (command) function as you like.  Try this [untested]:
(defun C:FY ()
  (command
    "_.layer" "_on" "*" "" ; just in case
    "_.DRAWORDER" (ssget "_X" (list '(8 . "S-WALLOV") (cons 410 (getvar 'ctab)))) "" "F"
    "_.DRAWORDER" (ssget "_X" (list '(8 . "S-WALLUN") (cons 410 (getvar 'ctab)))) "" "F"
    "_.DRAWORDER" (ssget "_X" (list '(8 . "S-MARKING") (cons 410 (getvar 'ctab)))) "" "F"
    "_.DRAWORDER" (ssget "_X" (list '(8 . "*HATCH*") (cons 410 (getvar 'ctab)))) "" "B"
    "_.REGENALL"
  ); command
  (princ)
); defun
It only finds things on the given Layer in the current space, in case you might have them in different Layouts.  That element of the (ssget) filter list could probably be eliminated, since the DRAWORDER command will only "see" things in the current space, anyway.  That should make it reducible to:
(defun C:FY ()
  (command
    "_.DRAWORDER" (ssget "_X" '((8 . "S-WALLOV"))) "" "F"
    "_.DRAWORDER" (ssget "_X" '((8 . "S-WALLUN"))) "" "F"
    "_.DRAWORDER" (ssget "_X" '((8 . "S-MARKING"))) "" "F"
    "_.DRAWORDER" (ssget "_X" '((8 . "*HATCH*"))) "" "B"
    "_.REGENALL"
  ); command
  (princ)
); defun
Kent Cooper, AIA
I should have said it's not right click it's enter, and I can see it happening when I do a line command before pressing the macro, the macro will cancel and attempt to draw a line, but will run fine still if I type it form command line. If I type CUI before running the macro it will pop up the window once per line but again no problem when typing the command I set. I will try get some logs when I am back at work.
