Store freezed layer in .lsp file
andreas7ZYXQ
andreas7ZYXQ
Im looking for a routine that stores the layer i freeze in a .lsp file.
It would work as follows:
User "layfrz" one or multiple layers. The routine then stores the layer name in a .lsp file in the same folder att the current dwg. formatted at a command.
(command "-layer" "f" "LAYER1" "")
(command "-layer" "f" "LAYER2" "")
etc...
If the file already exists then add the rows to the end.
Does anyone have something like this out there or could help me? It would be much appreciated.
ВeekeeCZ
Why to a *.lsp file? Can't think of a reason why that is a good idea.
Jonathan3891
It might help if you could explain what exactly you are trying to accomplish.
Jonathan Norton
Blog | Linkedin
Kent1Cooper
The idea seems to be to make a file you can run again later, or in another drawing, to freeze the same Layers.  I don't think it can be done in connection with the LAYFRZ command itself, because I don't know of a way to extract the Layer name(s) frozen with it, afterwards.  But I think this does it [very lightly tested]:
(defun C:LFAAF ; = Layer Freeze and Add to AutoLisp File
  (/ frzfile esel lname)
  (setq frzfile (open (strcat (getvar 'dwgprefix) "layfrzfile.lsp") "a"))
  (while
    (setq esel (entsel "\nSelect object to Freeze its Layer and Add a line to the Layer-Freeze AutoLisp file: "))
    (setq lname (cdr (assoc 8 (entget (car esel)))))
    (command "_.layer" "_freeze" lname "")
    (write-line
      (strcat "(command \"_.layer\" \"_freeze\" \"" lname "\" \"\")")
      frzfile
    ); write-line
  ); while
  (close frzfile)
It does not yet account for the possibility of picking something on the current Layer [which will cause an error], but could be made to.
Kent Cooper, AIA
andreas7ZYXQ
Thats what im looking for.
But if i try to freeze layers inside a xref it will freeze the xref layer.
Would it be possible to freeze layers inside xrefs?
Kent1Cooper
Well, you could add a letter:
  (setq esel (nentsel "\nSelect object to ...
But that goes to the deepest-nested level of whatever you pick on.  So if you pick on a Block in the Xref, and the part of the Block you pick on was drawn on Layer 0, it will Freeze Layer 0.  I have a way around that, but I can't take time to dig it out right now -- you can Search for a routine called LayerQuellPick.lsp, and look in its LFPN command.
Kent Cooper, AIA
