startapp windows explorer; can not open directory with comma
adrian_cruz-pc
adrian_cruz-pc
Checked the forums and couldn't find the answer (maybe I'm just not good with searching the forum?).
Using the standard (STARTAPP (strcat "EXPLORER /e," (getvar "dwgprefix"))) to open the directory of my drawing file.
Problem is when there is a comma in the path the routine will not work. Any solutions to opening directories that contain comma's?
Thx in advance.
adrian_cruz-pc
After looking, and many google searches. I found the solution to my own problem. I prefer using "dir" for my command input.
standard function:
(defun c:dir ()
(startapp "explorer" (strcat "/n,/e," (getvar "dwgprefix")))
)(princ)
Modified to open folders with comma's:
(defun c:dir ()
(startapp "explorer" (strcat "/n,/e," """\""(getvar "dwgprefix")))
)(princ)
TomBeauford
Odd, I've used this macro:
Name            Explore Here...
Description  Open Windows Explorer in Drawing Directory
Macro            ^C^C^P(progn(startapp "explorer" (strcat "/n,/e," (getvar "dwgprefix")))(princ))
Image            ExplorerBBox.png (attached)
and never had a problem with spaces in directories.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Shneuph
Thank you for sharing.  I've had this issue for years with a lisp that we use.  However, we never came across it often enough to really bother anything.  Now, I've updated it with your lines and works great!
Much appreciated.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
