startapp space in path
dolftromp
dolftromp
I use a lisp with startapp to open a textfile. This was working with Autocad 2015 without any problems, but now in 2018 it somehow has a problem with a space in the path to the file. If I could move the file I would already have done this, but its made by another lisp in the support folder of autocad.
(startapp "C:\\Program Files\\Notepad++\\notepad++.exe" "C:\\Users\\USERNAME\\AppData\\Roaming\\Autodesk\\AutoCAD 2018\\R22.0\\enu\\Support\\LMAC_BFind_SavedSearches_V2-0.txt")
I think there is a problem with the space in "\\Autocad 2018\\".
The weird thing is that in autocad 2015 I never had any problems with it.
Is there a way to still open this file?
CodeDing
@dolftromp ,
Checking the Documentation, it should be surrounded by literal quotes, like this:
(startapp "C:\\Program Files\\Notepad++\\notepad++.exe" "\"C:\\Users\\USERNAME\\AppData\\Roaming\\Autodesk\\AutoCAD 2018\\R22.0\\enu\\Support\\LMAC_BFind_SavedSearches_V2-0.txt\"")
Best,
~DD
dolftromp
@CodeDing ,
This works.
Thank you very much!
