ssget text with height of..
Can someone please help me understand this?
I am trying to select all text+mtext with text height no more than 250, then change it's style.
The part I seem to be tripping up on (at the moment at least) is the text height - "(40 . 250.0)".
I'm getting "Error: bad argument type: consp 250.0".
(setq ss3 (ssget "X" (list (cons 0 "TEXT,MTEXT")(40 . 250.0)(-4 "NOT>")(cons 410 (getvar "ctab")))))
(if ss3
	(progn
		(setq C 0)
		(repeat (sslength ss3)
			(setq entx (ssname ss3 C))
			(setq ent (entget entx))
			(setq ent (subst (cons 7 "RMS - 1.8mm")(assoc 7 ent) ent))
			(entmod ent)
			(setq C (+ C 1))
		); repeat
	); progn
); if
CodeDing
@Anonymous ,
Declare these as lists by adding the QUOTE in front of them. That should do it
(cons 0 "TEXT,MTEXT") '(-4 . "<") '(40 . 250.0)
Best,
~DD
UPDTAE:
I've already solved the error I was getting by making this change:
(setq ss3 (ssget "X" (list (cons 0 "TEXT,MTEXT")(cons 40 250.0)(cons 410 (getvar "ctab")))))
All i need now is to figure out how to make it select text LESS than 250..
I think I got it!
(setq ss3 (ssget "X" (list (cons 0 "TEXT,MTEXT")'(-4 . "<")(cons 40 250.0)(cons 410 (getvar "ctab")))))
