SSGET Selection area color
neam
neam
Hi everyone
How to set selection area color and continuance polygon like command "erase" "wp" in lisp (ssget)?
(princ "\nSelect Cogo Points by Widow Polygon : ")
(if (setq pt (getpoint "\nSpecify a point:"))
(progn
(setq ptlst (list pt))
(while (setq pt (getpoint pt "\nSpecify a point:"))
(redraw)
(setq ptlst (cons pt ptlst))
(grvecs (apply 'append (mapcar 'list ptlst (cdr ptlst))))
(setq ss (ssget "_WP" ptlst '(( 0 . "AECC_COGO_POINT"))))
(repeat (setq in (sslength ss))
(vla-highlight (vlax-ename->vla-object (ssname ss (setq in (1- in)))) :vlax-true)
Sea-Haven
This is how I make a window polygon for "F WP CP"
(command-s "pline")
(setq ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast)))))
(setq ptlst (cons (last ptlst) ptlst)) ; makes a closed list of points
paullimapa
If you want to see the Visual Effects of the selection window color then try this.
Replace these lines:
(progn
(redraw)
With these lines:
(progn
(command"_.Area" pt)
(redraw)
(command pt)
))(command"""_.Redraw")
Paul Li
IT Specialist
@The Office
