ssget for view coordinates
msarqui
Message 1 of 10
msarqui
Hi everyone!
I am trying to get a selection set to the view coordinates but with no luck.
Form here I get Lee Mac's code to get the coords.
(defun LM:ViewportExtents ( / c h v )
(setq c (trans (getvar 'viewctr) 1 0)
h (/ (getvar 'viewsize) 2.0)
v (list (* h (apply '/ (getvar 'screensize))) h)
(list (mapcar '- c v) (mapcar '+ c v))
But when I put it on the ssget it does not work.
(setq sel (ssget "_CP" (LM:ViewportExtents)))
Any help please?
Replies (9)
Message 2 of 10
pbejse
@msarqui wrote:
Hi everyone!
Any help please?
"CP" Requires 3 or more points. the function gives you 2.
(setq sel (ssget "C" (car (Setq pts (LM:ViewportExtents))) (cadr pts)))
HTH
Message 3 of 10
msarqui
Hi
It worked very well in the model and in the paper space, but not inside a block editor with a visibility parameter.
Any idea on how to solve for block editor?
Message 4 of 10
msarqui
Well, after some tests I'm starting to suspect that ssget does not select any parameters.
My goal is to move only the visible objects. Because I am using this in a block editor, could I use the "select" or the "move" command with coordinates?
Message 5 of 10
pbejse
Not sure what you mean by visible objects only msarqui, can you please tell us more.
Message 6 of 10
msarqui
Since I will use the selection inside the block editor and the block has visibilitys, I want to select only objects in the current visibility.
Message 7 of 10
pbejse
(command "-bedit" "Blockname" "_BVMODE" "0" "_bvstate" "_set" "visibilityname")
... [ select and do your thing ] ... (command "BCLOSE" "Save" "")
HTH
Message 8 of 10
msarqui
I am already inside the block editor when calling the code. So, I was thinking something like this:
(command "select" "CP" (car (LM:ViewportExtents)) (cdr (LM:ViewportExtents)))
Or this:
(command "move" "CP" (car (LM:ViewportExtents)) (cdr (LM:ViewportExtents)) "" "\\")
But It is not working because I thing I need four points here...
Message 9 of 10
pbejse
Or this:
use "C" instead of "CP"
(command "select" "C" (car (setq pts (LM:ViewportExtents))) (cadr pts))
if you insist on using "CP "
(setq sel (ssget "CP" (list (car pts) (list (caar pts)(Cadadr pts)) (cadr pts) (list (caadr pts) (cadar pts))) ) )
Message 10 of 10
msarqui
Thanks Patrick, that works.
