Visual LISP, AutoLISP and General Customization
Spot Elevation Tag With Two Measurement Units...
1 REPLY 1
spinalfarm
1359 Views, 1 Reply
Board,
Re: AutoCAD 2009
Is it possible to create a (somewhat) intelligent floor plan spot elevation tag with two units of measurement? Manually enter in the height of the floor level in imperial feet (ft.) & inches (in.) & have an automatic conversion to metric meters (m.) in brackets beside or below it?
This would ideally be a block with I am assuming a field with a formula?
Any help or suggestions would be super,
-STU
1 REPLY 1
in reply to: spinalfarm
Set up carefully enough, Ordinate Dimensions with Alternate Units will do exactly that.
Kent Cooper
spinalfarm wrote...
Board,
Re: AutoCAD 2009
-STU
Forma Design Contest
