Splitted list to string
Hi!
I've a list of elements wich are actually a range in Excel, I mean:
(setq i 1)
(setq my_rank (list 'A i ': 'B i))
I also have the GetCells.lsp function, and one of the arguments is the needed range. So, I must convert my_rank into a string. I've tried by using the strcat function but it doesn't work, I get a sort of error saying I'm giving a stringp...
Thank you so much
@Anonymous Try this?
_$ (setq i 1)
1
_$ (setq my_rank (list 'A i ': 'B i))
(A 1 : B 1)
_$ (vl-string-trim " ( ) " (vl-princ-to-string my_rank))
"A 1 : B 1"
_$
doaiena
Here is what i came up with:
_$ (apply 'strcat (mapcar '(lambda (x) (if (vl-symbolp x) (vl-symbol-name x) (itoa x))) my_rank))
"A1:B1"
_$
Satish_Rajdev
One more :
_$ (apply 'strcat (mapcar 'vl-princ-to-string my_rank))
"A1:B1"
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
Kent1Cooper
(setq i 1)
I also have the GetCells.lsp function, and one of the arguments is the needed range. So, I must convert my_rank into a string. ....
Dumb question, perhaps [I don't work with Excel files in connection with AutoCAD], but do you need the my_rank "middleman" variable at all?  Can you just build the string directly?
(strcat "A" (itoa i) ":B" (itoa i))
"A1:B1"
Kent Cooper, AIA
