split numbers and insert characters "+"
kajanthangavel
Message 1 of 17
kajanthangavel
I make a lisp for chainage marker. but i want to put "+" character in intro the number.
Ex:
Lisp make like this
5560.256
10201.250
15020.000
But I want like this
5+560.256
10+201.250
15+020.000
Please somebody help for modify this lisp code.
(defun c:ch (/ p1 ptx ro)
(setq P1 (getpoint "\nPick Chainage: "))
(setq ptx (car p1))
(setq ro (* 90 (/ pi 180)))
            (progn
              (entmakex
                (list (cons 0 "TEXT")
                      (cons 40 0.1)
                      (cons 10 p1)
                      (cons 50 ro)
                      (cons 1 (strcat (rtos ptx 2 3)))
(princ)
Replies (16)
Message 2 of 17
ВeekeeCZ
Just simply... hopefully understandable.
(defun ch+ (n / dz str len)
  (setq dz (getvar 'dimzin))
  (setvar 'dimzin 0)
  (setq str (rtos n 2 3))
  (setq len (strlen str))
  (setvar 'dimzin dz)
  (if (> len 7)
    (strcat (substr str 1 (- len 7)) "+" (substr str (- len 6)))
    str))
Message 3 of 17
dbhunia
You also can try this.......
(defun c:ch (/ p1 ptx ro ptx_len)
(setq ptx (car p1))
(setq ptx (strcat (rtos ptx 2 3)))
(setq ptx_len (strlen ptx))
(if (and (> ptx_len 7) (/= "-" (substr ptx 1 (- ptx_len 7))))
    (setq ptx (strcat (substr ptx 1 (- ptx_len 7)) "+" (substr ptx (- ptx_len 6))))
(progn
    (entmakex
	   (cons 40 0.1)
	   (cons 10 p1)
	   (cons 50 ro)
	   (cons 1 ptx)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 4 of 17
john.uhden
   (defun @FormatSta (sta xp prec / n sign str)
     ;; where:
     ;;  sta = real or integer
     ;;  xp = exponent of 10 to specify how many numeric charcters between "+" and "."
     ;;  prec = decimal precision
     (setq n (expt 10.0 xp))
     (setq sign (if (minusp sta) "-" ""))
     (setq sta (abs sta))
     (setq str1 (strcat sign (itoa (fix (/ sta n))) "+"))
     (setq str2 (rtos (* n (rem (/ sta n) 1)) 2 prec))
     (repeat (max (- xp (strlen str2))(- xp (vl-string-position 46 str2)))
       (setq str2 (strcat "0" str2))
     (strcat str1 str2)
For example:
Command: (@formatsta 56234.56 3 2)
"56+234.56"
Command: (@formatsta 56234.56 2 3)
"562+34.560"
John F. Uhden
Message 5 of 17
pbejse
@john.uhden wrote:
For example:
"56+234.56"
"562+34.560"
John,
Is there an industry standard for stationing?  when do you use  "56+234.56"  for 56234.56 and when is it "562+34.560"? Not a civil guy so... 🙂
Message 6 of 17
john.uhden
It is customary that metric uses thousands of meters, but imperial uses
hundreds of feet. Metric uses "chainage" and imperial uses "station."
Metric is usually 3 places after the decimal and imperial 2 places.
In the US (and maybe elsewhere), a chain was 66 feet long and consisted of
100 links.
A rod was 1/4 of a chain, or 16.5 feet.
Thus you will find many old road rights of way to be 2 rods, 3 rods, or 4
rods wide.
John F. Uhden
Message 7 of 17
dlanorh
and one acre is 160 sq rods. If anyone tells you they were the good old days, beat them into submission with the rod before wrapping them in the chain. Robot tongue
I am not one of the robots you're looking for
Message 8 of 17
john.uhden
I love it!
John F. Uhden
Message 9 of 17
pbejse
Cool beans.
Thank you for the info John,  the system variable MEASUREMENT would be the ideal reference for determining the as to when to use 3 or 2 places after the decimal then.
cheers
Message 10 of 17
john.uhden
That's very clever, if people actually use it.
I should at least include it as the default values.
John F. Uhden
Message 11 of 17
Kent1Cooper
@john.uhden wrote:
.... a chain was 66 feet long and consisted of 100 links.  A rod was 1/4 of a chain, or 16.5 feet. ....
In some cases it can get >even weirder< ....
Kent Cooper, AIA
Message 12 of 17
dbroad
Based on the initial code and the solution credited, I am curious, do all roads in India run west to east starting from 0 degrees longitude? 🙂
I say this because, in my experience, stationing is measured along a route. Routes rarely begin at a coordinate origin. They begin at the POB.  They also rarely run straight east forever from the origin.  I would think that a better approach than picking a point and keeping only its x-value would be to pick a polyline path and then pick a point on that path.  The stationing would be the distance along the path.
..Just saying...
Architect, Registered NC, VA, SC, & GA.
Message 13 of 17
dbhunia
Hi @dbroad I think you better know the answer of "do all roads in India run west to east starting from 0 degrees longitude?"  .....
What it can be?
Debashis Bhunia
Message 14 of 17
john.uhden
Do you mean Centigrade or Fahrenheit?
John F. Uhden
Message 15 of 17
dbhunia
No I want to mean Geometrifying Trigonometry.
Debashis Bhunia
Message 16 of 17
ВeekeeCZ
Hey guess, this is not fair.
I'm the one who you should blame for this poor solution. The guy is innocent, he just copy-pasted my poor suggestion. It's not his fault! I take full responsibility for my doing. I promise, that next time I'll be in India, I'll personally take a look whether I could possibly find any road not going east-west and let you know!
Message 17 of 17
john.uhden
You should follow one of Yogi Berra's pieces of advice... "If you come to a fork in the road, take it."
John F. Uhden
