Specifying the spline CV method in a script
leeminardi
Mentor Mentor
leeminardi
I am writing a Maxscript program to import Max splines into AutoCAD via a script file.  The program creates a .scr file like the following.
(setvar 'osmode 0)
spline
0.0,0.0,0.0
5.0,0.0,0.0
5.0,10.0,0.0
0.0,10.0,0.0
Note that the file ends with two blank lines.
The script assumes that the CV method of spline construction is active.   If I cut and paste the above into the AutoCAD command prompt it works fine. However, if I execute the script file, AutoCAD assumes the active method is Fit points.  I've tried several variations of including an "m" and "cv" to force the control vertex method for the script but have not been successful.
I tried:
spline m cv
but got the following.
Command: spline
Specify first point or [Object]: m
Point or option keyword required.
Any suggestions?  Thanks.
lee.minardi
ronjonp
Maybe this ?
(setvar 'osmode 0)
(setvar 'splmethod 1)
spline
0.0,0.0,0.0
5.0,0.0,0.0
5.0,10.0,0.0
0.0,10.0,0.0
Or hodge podge after the spline is created:
(vla-put-splinemethod (vlax-ename->vla-object (entlast)) 1)
This appears to work:
(setvar 'osmode 0)
(initcommandversion)
spline m cv
0.0,0.0,0.0
5.0,0.0,0.0
5.0,10.0,0.0
0.0,10.0,0.0
leeminardi
@ronjonp
initcommandversion worked, setvar 'splmethid 1, did not.
Thank you.  I'm not familiar with initcommandversion .
Lee
lee.minardi
ronjonp
Glad to help 🍻
