Source code organization
Message 1 of 32
Never having taken a programming class, let alone having a CS degree.
Everything I know about programming (not a lot) has been self taught through
books, this NG, source code, help files, etc.
I have about 200 or so different LSP files that I maintain. Most of them
have been completely hands off for years, but I have had to go into and
edit/update/modify a good chunk of. Either by creating new ones, improving
the most used routines, fixing bugs, what have you.
My question to the group is this. What kind of source code organization do
you gurus have? File/directory structure, grouping of functions by task,
stuff like that and what ever else you can think of.
Kevin Nehls
Replies (31)
Message 21 of 32
I guess that's what I really need to work on is an autoloader. Does this
autoloader autoload a routine when the command is called or when a function
is called or both? Is it basically the same as the autoloader that comes
with Autocad or Express Tools?
Currently I either pre-load routines or load them at run time, but they are
not autoloaded. Now that I'm typing these questions out and thinking about
it more it would be really cool to have functions autoloaded just by calling
them. Then you just have to maintain the autoloader file and not really
worry about where anything is located when using those functions/routines in
other routines. Using this method you could also make your directory
structure as flat or convoluted as you wanted. I think anyway, I'm going to
have to play around with this idea to get a better handle on it.
Kevin Nehls
"R. Robert Bell" wrote in message
news:[email protected]...
> Since I have an autoloader file (Toolbox.lsp) that autoloads *all* my
> functions, I don't need to go looking for anything, unless I need to edit
a
> function...
> R. Robert Bell, MCSE
> www.AcadX.com
Message 22 of 32
How does that work? Does it load on startup or on demand?
Timothy Spangler
Product Manager
Rasche Brothers Inc.
a
> function...
> www.AcadX.com
> "Timothy Spangler" wrote in message
> > My other thing is what about changing jobs or using multiple machines, I
> > want the ability to copy all of MY files out with little trouble. I
also
> > want to keep my functions separate from everything else (ACAD Standard
> > Files). As Far as the support path thing I just have a lisp that adds
all
> > of the directories I use with my lisp when I need it to. But I still
find
> > it hard to look in 1 or 2 folders of about 100+ routines each to find
what
> I
> > am looking for. How do you fix that?
Message 23 of 32
*Exactly*
I don't use AutoCAD's (or Express) autoloader, I created my own to fit my
circumstances.
And yes, I autoload functions in that Toolbox.lsp (which loads at startup)
so I may blissfully use my functions in my main code w/o worrying about
loading them.
To make the autoload as simple as possible, I wrote an internal load
function which performs the folder search (non-ACAD support folders),
handles file extension (vlx/fas/lsp), and bad functions (in case I make an
error in the autoload).
www.AcadX.com
"Kevin Nehls" wrote in message
function
are
about
calling
in
to
Message 24 of 32
See reply to Kevin.
www.AcadX.com
Message 25 of 32
Very good info. I'll have to take those points into consideration when (yes
when, not if) I write my own autoloader. I already have my own internal
load function, which does some checking, I just don't have the autoloader
portion setup. I'll probalby use Autocad's as a basis or at least an
example of how to construct one.
Thanks for the info.
Kevin Nehls
> www.AcadX.com
Message 26 of 32
Robert, i see that in your prefix you have this line 'Dependencies:
rrbI:Error, rrbI:VarSav'. i'm also in the process of organizing my programs
and i was wondering what your error function checked for and what variables
your varsav function saves.
any info would be helpful
thanks,
Rob
'There is no knowledge that is not power.'
W2k, A2K2, VB6, VB.NET
> As far as headers go, I settled on this awhile ago (see attached).
> My folder structure on the network is fairly flat also, with Toolbox
> routines stored in a folder under the "Program" folder.
> I do all development on my local drive (with frequent backups!) and
AutoCAD,
> on my laptop, uses these development folders as the primary support path.
> I also make sure that all toolbox functions have a unique prefix to help
me
> identify them (rrbI:).
> www.AcadX.com
> > This is all really good info. I don't really need to check the old
> version,
> > I just usually keep them around a couple of weeks incase a new version
> > introduces a major bug I didn't find. This way I can go back to the
> > previous version and work the bug out without everyone having to wait on
> > that getting fixed.
> > Some tasks are simple, some are complex and some are trying to make the
> > complex ones simple. For instance, I'm updating our "notes" routine to
> read
> > from a text file instead of inserting each note from a block.
Maintaining
> > 60+ dwg files for the different notes is a pain, but 1 text file is nice
> and
> > easy.
> > We're not selling any of this code. It's all just for company use.
> > Here's our setup.
> > Everyone has 1 local directory (by default) C:\acadmech, which is listed
> at
> > the top of the support paths. They can put anything in here they want
and
> > that I don't want on the server.
> > On the server (it's actually a pretty flat structure)
> > I:\Acad Files <- contains files installed by autocad, but customized by
> us
> > I:\Dev\Src <- contains the source code of all LSP files
> > I:\Dev\Update <- this is where I planned to work on updates and new
> > routines, but it usually ends up happening on my local system.
> > I:\Fonts <- duh
> > I:\SW Support <- Contains all "standard" compiled lsp files, menu files
> and
> > all "standard" blocks, there are a few sub-dirs of some specialty
blocks,
> > but that's it.
> > The overall file structure is pretty flat. I want to organize it into
> > categories so that if I ever left, someone new could take a look at it
and
> > any readme.txt files I have and get a pretty good understanding of
what's
> > going on. I also need to go through all of the routines to add some
> > description to them. I inherited most of what's going on here and have
> > re-worked some of it. It was a real pain when I first started with it,
> but
> > after 4+ years I now know where everything and mostly how it works.
> > Kevin Nehls
> SampleHeader.lsp
> Version history
> 1.1 2002/03/28 A sample just for you!
> 1.0 2002/01/01 Initial release.
> Here is where I describe the program/function
> Dependencies: rrbI:Error, rrbI:VarSav
> Usage: (rrbI:MyFunc Data)
> Arguments: Data type of argument, desription of argument's purpose
> Returns: description of return values
> Copyright © 2002 by R. Robert Bell.
> Written permission must be obtained to copy, modify, and distribute this
software.
> Permission to use this software for any purpose and without fee is hereby
granted,
> provided that the above copyright notice appears in all copies and that
both
> the copyright notice and the limited warranty and restricted rights notice
below
> appear in all supporting documentation.
> R. ROBERT BELL PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
> R. ROBERT BELL SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
> MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.
> R. ROBERT BELL DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM
> WILL BE UNINTERRUPTED OR ERROR FREE.
> [email protected]
> (defun...
Message 27 of 32
That is my generalized error handler. It simply checks for or nil, and
clean exits in those cases, running my rrbI:VarSav to restore the
environment.
rrbI:VarSav saves/sets specified setvars (provided as a list), and restores
them when called with a nil argument.
www.AcadX.com
"Rob Tomson" wrote in message
programs
variables
> thanks,
> Rob
> AutoCAD,
path.
> me
> > www.AcadX.com
> > version,
on
> > > that getting fixed.
the
to
> > read
> Maintaining
nice
> > and
> > > easy.
> > > Here's our setup.
listed
> > at
> and
by
> > us
> > > I:\Fonts <- duh
files
> > and
> blocks,
> > > but that's it.
> and
> what's
have
it,
> > but
> > > Kevin Nehls
> > SampleHeader.lsp
> > Version history
> software.
hereby
> granted,
> both
notice
> below
> > [email protected]
> > (defun...
Message 28 of 32
thanks!
and
> environment.
restores
> www.AcadX.com
> programs
> variables
> > thanks,
> > Rob
> > AutoCAD,
> path.
help
> > me
> > > www.AcadX.com
> > > version,
version
wait
> on
> > > > that getting fixed.
> the
> to
> > > read
> > Maintaining
> nice
> > > and
> > > > easy.
> > > > Here's our setup.
> listed
> > > at
want
> > and
customized
> by
> > > us
> > > > I:\Fonts <- duh
> files
> > > and
> > blocks,
> > > > but that's it.
into
it
> > and
> > what's
> have
> it,
> > > but
> > > > Kevin Nehls
> > > SampleHeader.lsp
> > > Version history
this
> > software.
> hereby
> > granted,
that
> > both
> notice
> > below
> > > [email protected]
> > > (defun...
Message 29 of 32
Kevin, (Hope its ok to interject)
My main program is called keymac.lsp. It is basically a file that contains
hundreds of autoload statements like for the closet rod below.
(I also use my own, since I started before Autodesk had theirs)
;;Sample part of keymac.lsp
;;restore previous error program and variable settings
;;(restore) ;<--Of course this is old hat now that you can use local *error* functions
(defun restore()
(if (list oerr) (setq *error* oerr))
(moder) ;;<-Just like Autodesk's version
(command "undo""end") ;5-14-95
(princ)
;;$INI initialize function
;;($INI )
(defun $ini (a) (princ "\nInitializing .....")(load a))
;;$INR initialize, redefine, and run
;;($inr ' ')
(defun $inr(a b c)
(restore)
($ini a)
(eval (list 'defun b nil c))
(eval c)
;For the closet rods the autoload looks like:
(defun c:cr ()($inr "crod" 'c:cr '(c:crod)));;DCB closet rod
Doug
> Kevin Nehls
> > www.AcadX.com
Message 30 of 32
No prob. Thanks for the info Doug.
Kevin Nehls
"Doug Broad" wrote in message
Message 31 of 32
Hi Kevin,
That's a problem I've had to ponder a lot in the past also. Here are a
couple of tricks you can use to make lisping easier I believe.
1. Apropos is great
One thing I did was to rename most of my functions at some point to make
them more logical and easier to find with the apropos in visual lisp. It was
a bit tedious to do but you can replace in files using many text editors and
you can search directories in visual lisp.
e.g if I had a function called getpointlist I might rename it to pts-get.
Other examples include:
centreofptlist - pts-get-centre
boundingbox - pts-get-boundingbox
sortpoints - pts-sort
scalepoints - pts-scale
printpoints - pts-print
do the same thing for entities (e.g. ent-get-color, ent-get-layer)
When you are trying to remember old functions just type in the obvious first
letters and use the apropos command to show you a list of possible
functions. By typing pts- and then holding down ctrl, shift and space-bar at
once you should get the above pts-* commands listed above. Therefore you
don't have to try to remember the name of the functions anymore as long as
the files are loaded into lisp memory.
2 . Encapsulate your files into projects
Try using visual lisp projects to associate files with one another. You can
keep all your source in certain directories and put your project compiled
fas files in your support path. I find this useful even if the files aren't
grouped together as an application. You can search through all files in a
project and open and close them easily with the projects window. And when
you compile the project it can reveal all sorts of naming conflicts and
unwanted local variables. You can also see what files dependencies exist so
that you don't give a lisp file to someone only to find that they are
missing certain libraries. I read about projects in the visual lisp pdf file
that comes with AutoCAD and I find them very useful for organising files.
I hope some of these suggestions come in handy,
Best of luck,
Chris Kelly
Message 32 of 32
Thanks Chris. I'll look into that info.
BTW, I posted an Autoloader function that you may be interested in. The
topic is titled "My AutoLoader (sort of)".
Kevin Nehls
"Chris Kelly" wrote in message
