sorting list of point
xuantientutungXUK6E
xuantientutungXUK6E
hello masters,
i have two list of point, for example A=( (1 0 1) (2 0 1) (4 5 1) ( 6 2 1))
        B=( (1 0 1) (1 0 1) (3 0 1) (4 5 1)  (4 5 1))
the task is find the difference points between two list A and B,
(Each point in list A only needs to be repeated at B once to be subtracted)
which result is a new list C=((1 0 1) (2 0 1) (3 0 1) (4 5 1) ( 6 2 1))
please guide me.
thank for your help.
Sea-Haven
For me the best way may be add the two lists together, then sort the big list based on the 3 items, you just compare two items and if = same then go to next making a result list.
I have what you want but its not in one bit of code. This is a good starting point
(defun compare-elements (a b sortspec)
( (lambda (x y test)
(if (and (equal x y ) (cdr sortspec))
(compare-elements a b (cdr sortspec))
(apply test (list x y))
(nth (cdar sortspec) a)
(nth (cdar sortspec) b)
(caar sortspec)
(defun complex-sort (alst sortspec)
(vl-sort alst
'(lambda (a b)
(compare-elements a b sortspec)
(setq lst (complex-sort lst '((< . 0) (< . 1) (< . 2))))
(setq lst3 '())
(setq x 0)
(repeat (- (length lst) 1)
(if (= (nth x lst)(nth (+ x 1) lst))
(princ "OK")
(setq lst3 (cons  (nth x lst) lst3))
Sea-Haven
Please ignore post above this is probably what you want
; make 1 list in order of two lists
; Alan H OCT 2019
(caar sortspec)
(vl-sort alst
'(lambda (a b)
(setq a (list (list 1 0 1)(list 2 0 1)(list 4 5 1)(list 6 2 1)))
(setq b (list (list 1 0 1)(list 1 0 1)(list 3 0 1)(list 4 5 1)(list 4 5 1)))
(setq lst (append a b))
(setq lst3 '())
(setq x 0)
(if (equal(nth x lst)(nth (+ x 1) lst))
(princ "match")
(setq x (+ x 1))
(setq lst3 (cons (nth  (- (length lst) 1) lst) lst3))
Kent1Cooper
If, as in your example, the A list would not have repeats as the B list can, and if the result doesn't need to be in any particular order, try this:
(defun C:whatever ()
  (setq
    listA '((1 0 1) (2 0 1) (4 5 1) ( 6 2 1))
    listB '((1 0 1) (1 0 1) (3 0 1) (4 5 1) (4 5 1))
    listC listA
  ); setq
  (foreach item listB
    (if (not (member item listA))
      (setq listC (cons item listC))
    ); if
  ); foreach
  listC
That can be sorted [presumably by X coordinate if your example is the desired order, but could be by other criteria].  If list A might also have duplicates, that can also be accounted for.
Kent Cooper, AIA
ronjonp
Give this a try too:
;;http://www.lee-mac.com/uniqueduplicate.html
;; Unique  -  Lee Mac
;; Returns a list with duplicate elements removed.
(defun LM:Unique ( l )
    (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l)))))
(setq l1 '((1 0 1) (2 0 1) (4 5 1) (6 2 1)))
(setq l2 '((1 0 1) (1 0 1) (3 0 1) (4 5 1) (4 5 1)))
( LM:Unique (append l1 l2) )
Sea-Haven
Should have known Lee as usual has a brilliant answer.
