Sort plus min max
Sort plus min max
Sort plus min max
Hi!
I have a little challenging problem. I have this list:
(setq mylist
  (list
    (a (25 3))
    (b (30 8))
    (a (60 8))
    (a (80 5))
    (b (50 7))
    (c (14 2))
Where the first element is the name of a place and the second one is their coordinates.Now I need the middle point for each group of letter at the first element and the biggest one of the second member in the second place. I mean:
(a (52.5 8))
(b (40 8))
(c (14 2))
I can't find any easy way to accomplish this simple task. Every help is welcome!
Best regards
rkmcswain
The data in your example doesn't match anything in the list above that. So you want to sort by the first number in the number pair, and in case of the same number, use the second number to sort?
R.K. McSwain     | CADpanacea | on twitter
ВeekeeCZ
Not sure if this is simple way, but it works...
(defun :sort-by-letter-mid-max (lst / l a)
  (foreach e lst
    (setq l (if (setq a (assoc (car e) l))
	      (subst (append a (cdr e)) a l)
	      (cons e l))))
  (vl-sort (mapcar '(lambda (x)
		      (list (car x)
			    (list (/ (apply '+ (mapcar 'car (cdr x)))
				     (- (length x) 1.))
				  (apply 'max (mapcar 'cadr (cdr x))))))
		   l)
	   '(lambda (a b) (< (car a) (car b)))))
For
(setq mylist '(("a" (25 3))
	       ("b" (30 8))
	       ("a" (60 8))
	       ("a" (80 5))
	       ("b" (50 7))
	       ("c" (14 2))))
result is:
(:sort-by-letter-mid-max mylist)
(("a" (55.0 8)) ("b" (40.0 8)) ("c" (14.0 2)))
john.uhden
vl-symbol-name?
John F. Uhden
