Sort list issue
Sort list issue
msarqui
Sort list issue
msarqui
Hi everyone,
How do I sort this list :
'(("CC = E03-A") ("CC = E04-A") ("B = G03-A") ("A = G03-A") ("C = G03-A") ("A = T03-C") ("B = T03-C") ("C = T03-D") ("AA = T06-D") ("BB = T06-H") ("AA = T06-H") ("BB = T06-I"))
To have this result :
'(("A = G03-A") ("A = T03-C")  ("B = G03-A") ("B = T03-C") ("C = G03-A") ("C = T03-D") ("AA = T06-D") ("AA = T06-H") ("BB = T06-H")  ("BB = T06-I") ("CC = E03-A") ("CC = E04-A"))
Thanks in advance,
Marcelo
Ranjit_Singh
There might be different ways of doing this. Here is one
(mapcar 'list (acad_strlsort (apply 'append lst)))
where lst is your list
 EDIT: That is a trick question Smiley Wink I just realized your output is not sorted alphabetically. Try this
(mapcar 'car (vl-sort (mapcar '(lambda (x) (cons x (strlen (vl-princ-to-string (read (car x)))))) (mapcar 'list (acad_strlsort (apply 'append lst)))) '(lambda (x y) (< (cdr x) (cdr y)))))
Again, there might be better ways of doing this that other members may suggest.
msarqui
Thanks Ranjit.Singh
Your edit code was the solution.
Kent1Cooper
It seems to me you could at least eliminate the
functions, and simply read the length of the strings directly:
(mapcar 'car
  (vl-sort
    (mapcar '(lambda (x) (cons x (strlen (car x))))
But that raises a question in my mind.  That seems to compare them by overall string length, assuming the only difference between any of them is whether they start with a single or a double letter.  Might there ever be some that are different in any other way, affecting their string length, such as perhaps [random variants on the first item here]:
("CC = E103-A")
or
("CC = E03-AA")
or
("CC = EE03-A")
or might you ever get as far as
("CCC = E03-A")
or who-knows-what-other possibilities?  If so, that raw string length comparison could throw off the results.
Kent Cooper, AIA
msarqui
It is also working Kent.
I will let you both know if I have future issues with this.
Many thanks!
