Some Lisp Routines Won't Work
Message 1 of 10
Hello;
We just upgraded to A2K, and forgive me if this question has come up before
(I couldn't find one though).
Some of our lisp routines, which worked fine in AutoCAD 14, do not work with
A2K, specially ones with command line "INSERT" i.e. Command "INSERT" "bla
bla bla".
Is there any changes that we need to know? Can you give us a hint? Thanks!
m.aaly@ssss.com
Replies (9)
Message 2 of 10
You need to prefix "INSERT" with "-" to ensure that
the command - line version of INSERT is used. There's
plenty of other gotcha's, but it's best to take 'em
one at a time.
poor wrote:
> Hello;
> bla bla".
> m.aaly@ssss.com
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 3 of 10
Thanks Tony for your reply.
I put a "-" in front of the word "INSERT". Still doesn't work right. It
asks the user for x, then y, and then z, a.....
Here is the code we have from R14:
(defun NEW_ERR (s)
(if (/= s "Function cancelled")
(princ (strcat "\nError: "s))
(setq *error* OLD_ERR)
(princ)
(defun C:CEN ()
(setq OLD_ERR *error* *error* NEW_ERR)
(setvar "CMDECHO" 0)
(setvar "ATTDIA" 1)
(setq scalef (* 1.12 (getvar "dimscale")))
(setq A (getpoint "\nSelect insertion point: "))
(command "-INSERT" "ZZ/Ylib/std/mech/Misc/Misc_21" A scalef "" "")
(princ)
(princ " CENTER LINE routine loaded ")
(princ)
Can you please shed some light in to this.
Regards;
m.aaly@ssss.com
Tony Tanzillo wrote in message
news:38D05B96.5FDF33B2@worldnet.att.net...
> one at a time.
> poor wrote:
> > Hello;
before
with
"bla
> > bla bla".
Thanks!
> > m.aaly@ssss.com
Message 4 of 10
That's right, the insert command did change. I experienced this when using the
(vla-InsertBlock) function which requires an extra parameter for the z-scale in
A2K.
Simply add "" to the end of your insert command so it becomes:
(command "-INSERT" "ZZ/Ylib/std/mech/Misc/Misc_21" A scalef "" "" "")
This should apply the same x-scale to y and z as well. Although I've found many
differences in the way ActiveX functions are handled in A2K, this is the only
command I know of which has changed. I'm sure someone else could shed light on
any others.
Good luck!
Andrew Wilford
visualdcl@mindspring.com
Visual DCL v1.0
http://www.mindspring.com/~cwilford/visualdcl.htm
------------Millennium special $89.95!-----------
Message 5 of 10
You're going to have to be more specific about the
problem, because I don't see any problem with the
code below.
Change the 0 in (setvar "cmdecho" 0) to 1, and then
run your code. Copy the output from the text window
and post it in a reply here.
> (defun NEW_ERR (s)
> (princ)
> (defun C:CEN ()
> (setvar "ATTDIA" 1)
> (princ)
> (princ)
> Regards;
> m.aaly@ssss.com
> > one at a time.
> > poor wrote:
> > > Hello;
> before
> with
> "bla
> > > bla bla".
> Thanks!
> > > m.aaly@ssss.com
Message 6 of 10
I don't believe there's any need to include the Z scale
factor, unless you type "XYZ" at the X scale factor
prompt.
Andrew Wilford wrote:
> Hi,
> A2K.
> any others.
> Good luck!
> Andrew Wilford
> Visual DCL v1.0
Message 7 of 10
hi;
Here is the copy&paste of text window:
Command: cen
Initializing... CENTER LINE routine loaded
Select insertion
point: -INSERT Enter block name or [?]:
Specify insertion point or
[Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
Enter X scale factor, specify
opposite corner, or [Corner/XYZ] <1>:
1.120000000000000 Enter Y scale
factor <use X scale factor>: Specify rotation
angle
<0>:
Enter attribute values
Enter first description line (if any):
Enter seond description line (if any):
Enter third description line (if
any):
Command:
As you can see, for some reason, there is no pause and
requirement for user input of "attribute" values.  Something is setting
them to blank and continues (block misc_21 has three lines of attribute first
line, second line, and third line).
In this line (command "-INSERT"
"ZZ/Ylib/std/mech/Misc/Misc_21" A scalef "" "" "" "")
  if I
remove two of double quotes, "" "", and leave it as (command
"-INSERT" "ZZ/Ylib/std/mech/Misc/Misc_21" A scalef "" "" ),
then program pauses and asks for Y and Z values?  I am so
confused.
Please, this was working fine with release 14.  What in
the world did Autodesk do.
Thanks for your help.
size=2>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
size=2>> You're going to have to be more specific about the
> problem,
> code below.
> run your code. Copy
reply.
z, a.....
> (defun NEW_ERR (s)
> >  (if (/= s "Function
cancelled")
"s))
>  (princ)
> > (defun C:CEN ()
> >  (setvar
"CMDECHO" 0)
> >  (setvar "ATTDIA" 1)
> >  (setq
> >  (setq A (getpoint
> >  (command "-INSERT"
> >  (setq
*error* OLD_ERR)
> >  (princ)
> > (princ "
> > (princ)
Regards;
href="mailto:m.aaly@ssss.com">m.aaly@ssss.com
> > Tony Tanzillo <
href="mailto:tony.tanzillo@worldnet.att.net">tony.tanzillo@worldnet.att.net
wrote in message
href="news:38D05B96.5FDF33B2@worldnet.att.net">news:38D05B96.5FDF33B2@worldnet.att.net
> > > plenty
> > > one at a
time.
> > > poor wrote:
> > > > Hello;
> > > > We just upgraded to
> > before
work
> > with
> > "bla
> > > > bla
bla".
> > Thanks!
Consulting     */
> > > /* Programming &
href="http://ourworld.compuserve.com/homepages/tonyt">http://ourworld.compuserve.com/homepages/tony...
Consulting     */
Message 8 of 10
Try changing your "ATTREQ" system variable.
-mjm
On Thu, 16 Mar 2000 16:06:37 -0600, "m.a." wrote:
>hi;
>Command: cen
>Select insertion point: -INSERT Enter block name or [?]: ZZ/Ylib/std/mech/Misc/Misc_21
>Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
>Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:
>1.120000000000000 Enter Y scale factor : Specify rotation
>angle <0>:
>Enter first description line (if any): Enter seond description line (if any):
>Enter third description line (if any):
>Command:
>As you can see, for some reason, there is no pause and requirement for user input of "attribute" values. Something is setting them to blank and continues (block misc_21 has three lines of attribute first line, second line, and third line).
>In this line (command "-INSERT" "ZZ/Ylib/std/mech/Misc/Misc_21" A scalef "" "" "" "") if I remove two of double quotes, "" "", and leave it as (command "-INSERT" "ZZ/Ylib/std/mech/Misc/Misc_21" A scalef "" "" ), then program pauses and asks for Y and Z values? I am so confused.
>Please, this was working fine with release 14. What in the world did Autodesk do.
>Tony Tanzillo wrote in message news:38D12860.8FA478B8@worldnet.att.net...
>> code below.
>> > (defun NEW_ERR (s)
>> > (princ)
>> > (defun C:CEN ()
>> > (setvar "ATTDIA" 1)
>> > (princ)
>> > (princ)
>> > Regards;
>> > m.aaly@ssss.com
>> > > one at a time.
>> > > poor wrote:
>> > > > Hello;
>> > before
>> > with
>> > "bla
>> > > > bla bla".
>> > Thanks!
>> > > > m.aaly@ssss.com
Message 9 of 10
Hey there!
We experienced a similar problem with our section mark routine. Our
routine inserts a block for a section mark. The block contains a circle
with a line across the centre and two attributes. Below is the code
that works for us in AutoCAD 2000. I thought it might help:
; insert circle part with section number and sheet number
(setvar "cmdecho" 1)
(setq sectnum (getstring "Section Number? (1) "))
(setq dwgnum (getstring "Drawing Number? (S2) "))
(setq sectins (getpoint "Insertion Point? "))
(command "INSERT" "SECTMARK" "SCALE" sf sectins "0" sectnum dwgnum)
Basically, we gather the input from the user first, and then issue the
Insert command.
Good luck!
Martin
"m.a." wrote:
> hi; Here is the copy&paste of text window: Command: cenInitializing...
> ZZ/Ylib/std/mech/Misc/Misc_21Specify insertion point or
> rotation
> angle <0>:
> (if any):
> Command: As you can see, for some reason, there is no pause and
> attribute first line, second line, and third line). In this line
> program pauses and asks for Y and Z values? I am so confused. Please,
> do. Thanks for your help.
Message 10 of 10
Thanks for all of you wonderful people for helping out. Every little line
helped. Thanks.
I think we have got it now working in a way. I had to add (command "DDATTE"
"l") in order to open attribute dialog box.
"Martin Klingbeil" wrote in message
news:38D25276.F172E5EC@walterschambers.com...
> Hey there!
> Insert command.
> Good luck!
> Martin
> > rotation
> > angle <0>:
> > (if any):
