Solution for covert below python program to lisp program in autocad
kadamsudarshan57
kadamsudarshan57
(import 'matplotlib.pyplot as plt)
(import 'numpy as np)
(def elevation_points (list (list 0 100) (list 5 150) (list 10 100) (list 15 120) (list 20 80)))
(def section_points (list (list 0 50) (list 5 75) (list 10 50) (list 15 60) (list 20 40)))
(plt.figure (figsize (list 10 5)))
(plt.plot (apply 'zip (apply 'list elevation_points)) :marker "o" :linestyle "-" :color "b")
(plt.title "Elevation Profile")
(plt.xlabel "Distance (m)")
(plt.ylabel "Elevation (m)")
(plt.savefig "elevation_plot.png")
(plt.show)
(plt.plot (apply 'zip (apply 'list section_points)) :marker "o" :linestyle "-" :color "r")
(plt.title "Section Profile")
(plt.savefig "section_plot.png")
(plt.show))
daniel_cadext
Matplotlib isn’t in lisp autolisp, why not use pyautocad?
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
kadamsudarshan57
Thank-you sir but py autocad  means
kadamsudarshan57
Sir please automatic building section command creat by auto lisp program all type of 2d plan
kadamsudarshan57
Please make  command 2d building section on 2d floor get point,put all heights for all type building plan  on 2d floor plan by autolisp program or command
hosneyalaa
if possible to drop here sample dwg file
daniel_cadext
Pyautocad is here:
You can interact with AutoCAD using ActiveX, kind of like VBA, but using python
https://pypi.org/project/pyautocad/
https://github.com/reclosedev/pyautocad
For the more advanced and adventurous :
You can use PyRx and wxPython to show matplotlib plots, a small example
#imports
from numpy import arange, sin, pi
import matplotlib
matplotlib.use('WXAgg')
from matplotlib.backends.backend_wxagg import FigureCanvasWxAgg as FigureCanvas
from matplotlib.figure import Figure
import PyRx as Rx
import PyGe as Ge
import PyGi as Gi
import PyDb as Db
import PyAp as Ap
import PyEd as Ed
import wx
#imports
#define a command
def PyRxCmd_wxpy():
    try:
        res = Ap.ResourceOverride()
        dlg = TestDialog(None, -1, "Plot",wx.Size(500,300))
        if dlg.ShowModal() == wx.ID_OK:
            print("Yay!")
    except Exception as err:
        print(err)
class CanvasPanel(wx.Panel):
    def __init__(self, parent):
        wx.Panel.__init__(self, parent)
        self.figure = Figure(figsize=(1,1))
        self.axes = self.figure.add_subplot(111)
        self.canvas = FigureCanvas(self, -1, self.figure)
        self.sizer = wx.BoxSizer(wx.VERTICAL)
        self.sizer.Add(self.canvas, 1, wx.LEFT | wx.TOP | wx.GROW)
        self.SetSizer(self.sizer)
        self.Fit()
    def draw(self):
        t = arange(0.0, 3.0, 0.01)
        s = sin(2 * pi * t)
        self.axes.plot(t, s)
class TestDialog(wx.Dialog):
    def __init__(
            self, parent, id, title, size, pos=wx.DefaultPosition,
            style=wx.DEFAULT_DIALOG_STYLE, name='dialog'
        wx.Dialog.__init__(self)
        self.SetExtraStyle(wx.DIALOG_EX_CONTEXTHELP)
        self.Create(parent, id, title, pos, size, style, name)
        Ap.Application.applyHostIcon(self.GetHandle())
        self.pltpanel = CanvasPanel(self)
        self.pltpanel.draw()
