solution cad
solution cad
tongminh97
solution cad
tongminh97
Hello, is there a way for me to know whether all my lines are connected to each other or not? Thank you.
ec-cad
Set your OSNAP settings to "Intersection" and turn off all other settings.
Hover above the lines of interest, should show a hour-glass type little icon at the Intersection point.
There is way in Lisp to pick a couple of lines of interest, and see if they intersect or not.
ECCAD
Sea-Haven
Do a google this is not a new question, it has been answered many times, the over-riding question is which end point do you move ? I am sure someone who answered this question previously will respond.
google something like this "find non matching end points autocad lisp"
tongminh97
Thank you for your answer.But the solutions I found online don't solve the case where a line intersects the middle of another line, like in the image.Other solutions only work for cases where the endpoints of two lines are connected.
paullimapa
Try BPOLY, Pick Points
Click Close & Esc to cancel command then zoom out or in a little with the wheel
Regen to remove those red circles drawn
Paul Li
IT Specialist
@The Office
tongminh97
ok thank Pau
paullimapa
You’re welcome…cheers!!!
Paul Li
IT Specialist
@The Office
