SNAPMODE and OSMODE Toggle command
CHRISTINA_GAITANTZI_35734
Hello, everyone! I've been trying to create a simple lisp command that, depending on the value of the system variable SNAPMODE (either 0 or 1), toggles between two states of set values for both SNAPMODE and OSMODE. I want to be able to achieve the following:
  • If SNAPMODE equals 0, set SNAPMODE to 1 and OSMODE to 0.
  • If SNAPMODE equals 1, set SNAPMODE to 0 and OSMODE to 72.
I would have thought that with my barely basic knowledge of LISP I could easily figure it out using a few lines, but I guess not. I'm pasting the code I wrote, so maybe you guys can help me out.
;; Switch from OSMODE Snap to SNAPMODE Grid
(defun C:SGS ()
	(if (= "SNAPMODE" 0)
		(progn (setvar "SNAPMODE" 1) (setvar "OSMODE" 0));progn true
		(progn (setvar "SNAPMODE" 0) (setvar "OSMODE" 72));progn false
	);if
	(princ)
);defun SGS
(princ)
Thanks in advance!
johnyDFFXO
Just a hint - you're missing GETVAR.
Thanks a lot! I was missing just that!
In any case, for anyone who may be interested, I'm pasting the new code below:
(defun C:SGS ()
	(if (= (getvar 'SNAPMODE) 0)
		(progn (setvar 'SNAPMODE 1) (setvar 'OSMODE 0));progn true
		(progn (setvar 'SNAPMODE 0) (setvar 'OSMODE 72));progn false
	);if
	(princ)
);defun SGS
(princ)
