Hello
This beautiful routine "UNDYNAMIC" acts on ALL dynamic blocks (and even on locked layers !) = OK
Please I need a special version :
- 1 - Use standard ACAD Selection (not ALL the DWG)
- 2 - Don't run on selected Dynamic Blocks on locked layers !
- 3 -All resulting Blocks are numbered STATIC_00-STATIC_99 or something like that !?
I need a small improvment on this NEW name :
At the beginning of the routine, Ask for the Prefix Name (default="STATIC_") ? xxxxxx
Begin with xxxxxx_100000 to xxxxxx_999999
Thanks in advance, Regards, Patrice
Patrice BRAUD
Solved by lando7189. Go to Solution.
Hello
SORRY I have forgotten a small DWG to test !
I would like to transform to STATIC ONLY the blocks at the bottom with a standard ACAD selection ...
Regards, Patrice
Patrice BRAUD
Give this a whirl.
- Lanny
;; ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/dynamic-block-to-static-block-renamed-after-visibility-state/m-p/7257238#M356330 ;; ;; http://www.theswamp.org/index.php?topic=32681.msg382548 ;; ;; Routine: UnDynamic by MP Seagull - March 26, 2010 ;; ;; MODIFIED BY Lanny Schiele (aka 'HatchMaker Maker') - 10/27/2017 ;; (vl-load-com) (defun c:UnDynamic ( / _DefGetString _get_item _right _make_key _dynamic->static_block _get_locked _get_dynamic_inserts _main ) ;;;* GET STRING WITH DEFAULT (defun _DefGetString (prmpt default allowspace / d2) (if allowspace (setq ans (cond ((not (= (setq d2 (getstring T (strcat prmpt " <" default ">: ")) ) ;_ end of setq "" ) ;_ end of = ) ;_ end of not d2 ) (default) ) ;_ end of cond ) ;_ end of setq (setq ans (cond ((not (= (setq d2 (getstring (strcat prmpt " <" default ">: "))) "" ) ;_ end of = ) ;_ end of not d2 ) (default) ) ;_ end of cond ) ;_ end of setq ) ;_ end of if ans ) ;_ end of defun (defun _get_item ( collection key / item ) (vl-catch-all-apply '(lambda ( ) (setq item (vla-item collection key))) ) item ) (defun _right ( str n / len ) (if (< n (setq len (strlen str))) (substr str (1+ (- len n))) str ) ) (defun _make_key ( collection prefix len / key ) ( (lambda ( i pad ) (while (_get_item collection (setq key (strcat prefix (_right (strcat pad (itoa (setq i (1+ i)))) len ) ) ) ) ) key ) ;;;0 99999 ( (lambda ( pad ) (while (< (strlen pad) len) (setq pad (strcat "0" pad)) ) pad ) "" ) ) ) (defun _dynamic->static_block ( blocks insert len ) (vla-ConvertToStaticBlock insert (_make_key blocks *UnDynamic:Prefix* len) ) ) (defun _get_locked ( layers / locked ) (vlax-for layer layers (if (eq :vlax-true (vla-get-lock layer)) (setq locked (cons layer locked)) ) ) locked ) (defun _get_dynamic_inserts ( blocks / block object inserts ) (vlax-for block blocks (vlax-for object block (if (eq "AcDbBlockReference" (vla-get-objectname object)) (if (eq :vlax-true (vla-get-isdynamicblock object)) (setq inserts (cons object inserts)) ) ) ) ) inserts ) (defun _get_dynamic_inserts_from_pickset ( ss / i object inserts ) (setq i 0) (while (< i (sslength ss)) (setq object (vlax-ename->vla-object (ssname ss i))) (if (eq "AcDbBlockReference" (vla-get-objectname object)) (if (eq :vlax-true (vla-get-isdynamicblock object)) (setq inserts (cons object inserts)) ) ) (setq i (1+ i)) ) inserts ) (defun _main ( document / ss blocks inserts locked len ) (if (not *UnDynamic:Prefix*) (setq *UnDynamic:Prefix* "STATIC_") ) (if (and (setq blocks (vla-get-blocks document)) (setq ss (ssget ":L" (list (cons 0 "INSERT")))) (setq inserts (_get_dynamic_inserts_from_pickset ss)) (setq *UnDynamic:Prefix* (_DefGetString "\nPrefix for static block names" *UnDynamic:Prefix* T)) ) ;;; (setq inserts ;;; (_get_dynamic_inserts ;;; (setq blocks (vla-get-blocks document)) ;;; ) ;;; ) (progn ;;; (foreach layer (setq locked (_get_locked (vla-get-layers document))) ;;; (vla-put-lock layer :vlax-false) ;;; ) ;;; (setq len (strlen (itoa (length inserts)))) (setq len 6) (foreach insert inserts (_dynamic->static_block blocks insert len) ) ;;; (foreach layer locked ;;; (vla-put-lock layer :vlax-true) ;;; ) (princ "\n...done.") ) (princ "\nNo dynamic blocks found - no block inserts were changed.") ) (princ) ) (_main (vla-get-activedocument (vlax-get-acad-object))) ) ;|«Visual LISP© Format Options» (72 2 40 2 T "end of " 60 2 0 0 0 nil T nil T) ;*** DO NOT add text below the comment! ***|;
Patrice BRAUD
Hello Lanny
THANKS it's exactly what I need !
Sorry for my delay to test and VALIDATE, Regards, Patrice
Patrice BRAUD
Hi I would like to tell that this is an excellent routine. I would like to know if it can be improved by adding one more action.
I need to use this routine which is fantastic but my dynamic blocks have fields with calculations on it and when I do the undynamic those fields become lost and ilegible.
What I would like to know is if this same undynamic routine can include a convert field to text before the undynamic action.
I have a lisp which I found it her as well and I would like to know a way to join both together.
Simple field to text + undynamic, by selection
Thank you in advance
Hi there, can you please modify it so that it automatically does
Regards
