Skipping text styles?
DC-MWA
Message 1 of 10
DC-MWA
Hi all,
I've been looking for a way to make all text styles in a drawing use "arial.ttf" font.
I've found a program that works but for some reason it skips certain text styles (seemingly random)???
Not sure why. Otherwise it works way better than the other versions i found.
Hoping someone can take a look at this and solve it.
thanks.
Replies (9)
Message 2 of 10
dlanorh
Try this
(defun c:AllArial (/ *error* c_doc c_tstys n_font)
  (defun *error* ( msg )
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg)))
    (princ)
  );end_defun *error*
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_tstys (vla-get-textstyles c_doc)
        nw_font (strcat (getenv "systemroot") "\\Fonts\\Arial.ttf")
  );end_setq
  (cond (nw_font
          (vlax-map-collection c_tstys '(lambda (x) (vlax-put-property x 'fontfile nw_font)))
          (vla-regen c_doc acallviewports)
        ( (alert "Could not find Arial font"))
  );end_cond
  (princ)
);end_defun
I am not one of the robots you're looking for
Message 3 of 10
SeeMSixty7
Can you attach a sample drawing that has some styles that don't change?
Message 4 of 10
Kent1Cooper
I don't see any obvious reason.  But try this, which is not only shorter, but doesn't change the current Text Style, so it doesn't require *error* handling to change it back.  And because it doesn't use any commands, it's probably also faster, though you probably wouldn't notice the difference unless you have a pretty large number of Styles.
(defun C:ALLARIAL (/ sname sdata)
  (while (setq sname (cdr (assoc 2 (tblnext "style" (not sname)))))
    (setq sdata (entget (tblobjname "style" sname)))
    (entmod (subst '(3 . "ARIAL.TTF") (assoc 3 sdata) sdata))
  ); while
  (princ)
); defun
Kent Cooper, AIA
Message 5 of 10
DC-MWA
Hi Kent This works but when you look at the fonts in styles it looks like as if the font can't be found?
Message 6 of 10
DC-MWA
This works.
Message 7 of 10
DC-MWA
I've got this working. Seems to be really fast works well.
Message 8 of 10
SeeMSixty7
Anyway to get the drawing sample with the styles that had an issue. I enjoy tracking that kind of stuff down. grin. I'd like to know why it was and was not working with the original code.
Thanks.
Message 9 of 10
DC-MWA
Sorry, I got caught up in the heat of the moment lol
I have attached a drawing with the styles within.
Message 10 of 10
SeeMSixty7
Your lisp routine was stepping through the style table until (cdr (assoc 2 (tblnext "style"))) returned nil. Problem is it was only processing the first 4 styles in that drawing. There is a blank style entry in the style table, most likley at one point or another it was used for a linetype in the drawing. Solution to rid the drawing of this would be to assign it a name and then delete it. Caution though it could be a hack by Civil 3D for something odd. To make your lisp routine work you would simply watch for the nil style name in your code.
((0 . STYLE) (2 . Standard) (70 . 0) (40 . 2.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 2.0) (3 . arial.ttf) (4 . ))
((0 . STYLE) (2 . Arch-Dim) (70 . 0) (40 . 2.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 2.0) (3 . arial.ttf) (4 . ))
((0 . STYLE) (2 . RomanS) (70 . 0) (40 . 2.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 2.0) (3 . arial.ttf) (4 . ))
((0 . STYLE) (2 . MWA-med) (70 . 0) (40 . 2.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 2.0) (3 . arial.ttf) (4 . ))
((0 . STYLE) (2 . ) (70 . 1) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.2) (3 . ltypeshp.shx) (4 . ))
((0 . STYLE) (2 . MWA-SMALL) (70 . 0) (40 . 0.0859375) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.0859375) (3 . arial.ttf) (4 . ))
((0 . STYLE) (2 . MWA-LG) (70 . 0) (40 . 0.1875) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.1875) (3 . arial.ttf) (4 . ))
((0 . STYLE) (2 . ScheduleData) (70 . 0) (40 . 0.0) (41 . 0.75) (50 . 0.0) (71 . 0) (42 . 0.09375) (3 . romans.shx) (4 . ))
((0 . STYLE) (2 . RomanSNarrow) (70 . 0) (40 . 0.0) (41 . 0.75) (50 . 0.0) (71 . 0) (42 . 1.0) (3 . romans.shx) (4 . ))
((0 . STYLE) (2 . TB_SMALL) (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.326093) (3 . arial.ttf) (4 . ))
Here is your code updated, just in case.
(defun c:allarial (/ Oldtstyle Sttxt Userfont *error*)
  (defun *error* (s)
    (setvar "textstyle" oldtstyle)
  (setq oldtstyle (getvar "textstyle"))
  (setq userfont "arial.ttf") ;_ <<<<change this for your textfont
  (setq sttxt (tblnext "style" t))
  (while sttxt
  	 (if (cdr (assoc 2 sttxt))
  	   (progn
  	  	  (setvar "textstyle" (cdr (assoc 2 sttxt)))
          (command "._Style" "" userfont 2 1 0 "N" "N")
     (setq sttxt (tblnext "style"))
  (princ)
good luck.
