single door lisp
single door lisp
tpl_arch
Message 1 of 11
single door lisp
tpl_arch
Can someone please tell me why this lisp works in R14 and not in 2008?
The routine starts fine but ends half way through,when it asks "which side" for the door swing.
It's the only one of about 15 cusom routines that won't work properly in 2008.
What do I need to change to make it work?
Replies (10)
Message 2 of 11
hmsilva
Hello  tpl.arch and welcome to the Autodesk Community!
In order to be able to assist, could you please post the sub-functions used in this code?
Henrique
Message 3 of 11
tpl_arch
I'm sory Henrique, but I don't know what you mean by "sub functions".
I don't write these lisps, I just use them....if you tell me where to look, I'll send you whatever you need.
thanks,
Tim
Message 4 of 11
hmsilva
Tim,
the code you've posted, have some sub-functions, store, width and brkwall, and some global variables, size >90.
The problem is to find where those functions and global variables are loaded, may be from acad.lsp, acaddoc.lsp, another file loaded at startup, from a menu, etc
Try to find those functions in one of those files...
Henrique
Message 5 of 11
Kent1Cooper
To be a little more specific, you want to look for a file, hopefully with the .lsp filetype ending, that contains somewhere in it
(defun store
which will probably contain within it something like
(setq >90  and likely also  (setq thick  and  (setq ang2
and a file or files that contain(s)
(defun brkwall  and  (defun side  and  (defun width
Those (defun things and the code that follows them define the sub-functions or sub-routines that your posted routine uses, but that are not native AutoLisp functions.  The (setq ones are setting variables that it uses, though they may not all be there, given that it sets some of them itself it they're not set already.
They could all be in one file, or in separate ones, or some in one and some in another.  If they're available to you in any drawing without your loading them yourself, then they are most likely defined either in an acaddoc.lsp file directly, or in files that it loads with  (load  functions.  Look for that file, and within it for either those sub-function definitions or files that are loaded which probably contain those definitions.  Look at the latter, if any, for the sub-function definitions.  Post the contents of those if they're .lsp files, and not proprietary or something.
However, they could be defined in some kind of compiled file(s) with a filetype ending such .vlx or .fas, in which case you won't be able to get at the definitions -- you would need to ask whoever compiled them for the source code.
Kent Cooper, AIA
Message 6 of 11
tpl_arch
could what you're looking for be in one of these lisps?
I'm still not understanding why a similar lisp works but not the one I orignially sent.
Check out the ddr.lsp here and see if you can find out the difference.
p.s. the lisp I'm trying to sent is being rejected by this posing method:
  • The attachment's V_MAIN.LSP content type (application/octet-stream) does not match its file extension and has been removed.
Can I email it to you?
Thanks guys!
Message 7 of 11
hmsilva
EDIT:
if you open the file in notepad.exe, can you read the file?
If so, zipp the file and attach the .zip file, if not, the file, most likely is not a .lsp file, or is encrypted, or someone changed the file extension...
Henrique
Message 8 of 11
tpl_arch
see if this works...
Message 9 of 11
hmsilva
Hi tpl.arch,
the functions required to run the V_DR.lsp are in V_MAIN.lsp, you´ll have to load the V_MAIN.lsp before run the V_DR.lsp, and It should work as expected.
Hope this helps,
Henrique
Message 10 of 11
tpl_arch
WOW!!!!!
You did it!!!!
Thanks so much...I never had any idea that it mattered which order they went into load apps.
I like my trusty old (very old) lisp...but it's the way we'v been drawing it for years and it looks good on our drawings.
Tim
Message 11 of 11
hmsilva
You're welcome, Tim!
One way to ensure that the Main code is loaded in every drawing, is creating or editing if already exists the acaddoc.lsp file, and add a
(load "V_MAIN.lsp" nil)
if the .lsp file is in one of the Support File Search Path directory, or
(load "c:\\the\\full\\path\\V_MAIN.lsp" nil)
if not.
Henrique
