simulate pressing a key while grread is active?
cadomatic
Message 1 of 11
cadomatic
I have a function that uses grread.
While grread is running, I use a key to manipulate the cursor shape.
I want to add the option to use a ribbon button for this as well.
However, if I add a macro for the button, such as "R," it terminates grread.
Is it possible to use a button macro as an option trigger for a command line command? Specifically, can the button simply simulate pressing "R" while grread is active?
thanks
S
Replies (10)
Message 2 of 11
komondormrex
hey,
i think it shouldn't terminate grread, but you cannot distinguish the macro itself because grread will give you sort of (11 -1) on every toolbar or ribbon item click. so technically, you can switch cursors by clicking on any toolbar or ribbon item. you also can use right-click for that purpose.
Message 3 of 11
cadomatic
what is 11-1?
the macro in the button terminates grread.
my grread used R to manipulate action , if i macro R in the button, it terminates grread and calling redraw
Message 4 of 11
komondormrex
that is what grread returns.
Message 5 of 11
cadomatic
i dont understand.
what is the meaning of 11-1 returned by grread?
and what it have to do with the original problem?
Message 6 of 11
komondormrex
you catch that list while grread is active and switch cursor then.
Message 7 of 11
cadomatic
im not sure we are taking about the same thing.
with grread active , user can press a key to do something.
i want to allow the user to press a button instead of using that key.
but when i try , the grread is terminated. autocad treat that as a new command and not as a key pressed while grread is running.
Message 8 of 11
komondormrex
are you going to use grread's curtype argument to change cursor or draw extra exotic self drawn one?
Message 9 of 11
cadomatic
grread is used to attach a rectangle to the cursor. pressing R rortate that rectangle
Message 10 of 11
komondormrex
some similar to this? right-click rotation.
Message 11 of 11
cadomatic
kind of. do you press any key to rotate it?
let say you press R , but i cant set a button that simulate pressing R
