Simple text move
Simple text move
BB8x
Message 1 of 8
Simple text move
BB8x
Hello
I need lisp to move x/y all texts based on their rotation in direction shown on attached screenshot
I would imagine this as reading text rotation, add (or remove) 90 deg and calculate azimuth. Then move text insertion point with azimuth and distance of 0.05 units
Replies (7)
Message 2 of 8
Kent1Cooper
Yes, exactly, though as described and illustrated, always adding 90°.  Here's one way to do it:
(defun C:TU05 ; = Text Upwards by 0.05 units
  (/ ss n txt ins)
  (if (setq ss (ssget '((0 . "TEXT"))))
    (repeat (setq n (sslength ss))
      (setq txt (ssname ss (setq n (1- n))))
      (setpropertyvalue txt "Position"
        (polar
          (getpropertyvalue txt "Position")
          (+ (getpropertyvalue txt "Rotation") (/ pi 2))
          0.05
  (princ)
That calls for User selection.  If you really want to do all Text objects without User selection:
  (if (setq ss "_X" (ssget '((0 . "TEXT"))))
And it assumes you meant Text objects specifically, not [or not also] Mtext, but if you need Mtext too [whether or not you include the "_X"]:
  (if (setq ss (ssget '((0 . "*TEXT"))))
Kent Cooper, AIA
Message 3 of 8
Sea-Haven
Just a suggestion for "X" so moves within only current tab.
(if (setq ss "_X" (ssget '((0 . "TEXT")(cons 410 (getvar 'ctab)))))
Message 4 of 8
BB8x
I have "ads request error"
Message 5 of 8
TomBeauford
Maybe it would be best to modify the code or procedure that's placing the text incorrectly to avoid having to fix it ever again.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 6 of 8
john.uhden
@BB8x
We don't know what version of AutoCAD you are using.
@Kent1Cooper ,  @ВeekeeCZ  when did getpropertyvalue come along?
John F. Uhden
Message 7 of 8
TomBeauford
4 new AutoLISP functions in A2012
 http://www.theswamp.org/index.php?topic=39259
2023
Message 8 of 8
Sea-Haven
getproperty not supported in Bricscad and maybe other non acad software.
