Simple Lisp to select everything on layer and explode/join
Im dealing with lines and polylines in particular.
Im looking for a small and simple lisp that selects everything on a layer, "ROW", and explode it.
Im also looking for a lisp that selects everything on a layer, "ROW" and joins it
hak_vz
(defun c:selrow  nil (setq ss  (ssget "_X" '((8 . "ROW")))))
Whenever you have to use  explode or join something in layer "ROW" use command selrow to create selection set.
Then simply start command EXPLODE or JOIN and as a argument to select objects in layer "ROW"  enter !ss and hit enter
Miljenko Hatlak
(defun c:exrow  ()
  (setq ss
      (ssget "_X" '((8 . "*ROW"))
   (command "explode" "!ss")
I have to do this command over and over in at least a couple hundred drawings. I wanted to get it into a single command if possible. Can you help me complete the lisp above?
hak_vz
(defun c:exrow  ()
  (setq ss
   (setvar 'qaflags 1)(command "_.explode" ss "")(setvar 'qaflags 0)
   (princ)
(defun c:jorow  ()
  (setq ss
   (setvar 'qaflags 1)(command "_.join" ss "")(setvar 'qaflags 0)
   (princ)
Miljenko Hatlak
Sea-Haven
Missing the what if its not "Row"
(setq ent (entsel "\nPick object for layer "))
(setq lay (cdr (assoc 8 (entget (car ent)))))
(setq ss (ssget (list (cons 8 lay))))
