Shortcuts and commands in Lisp
carlos_m_gil_p
carlos_m_gil_p
Hello boys how are you. I wanted to consult something. There is some way to make the shortcut and command appear at the same time. As when you are going to activate the line command, just type the letter L and the line name is also shown.
L (LINE)
I want to make my Lisp show up that way.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
ВeekeeCZ
The command can be LISP but the shortcut has to be assigned at acad.pgp file.
carlos_m_gil_p
Thanks for the explanation.
I thought it was something that is added at the time of doing the main function.
(defun c: .....
Greetings.
AutoCAD 2026
