Shifting viewports
Shifting viewports
Shifting viewports
Hi all,
I was wondering if you could somehow shift a viewport center x location by a specific amount throughout multiple layouts? The problem i am having is that I have numerous layouts of a model and making a change to the beginning of the model (adding 2") will result in all layout viewports to be shifted by that amount. I then have to go into each layout and resize the viewport to display what it did before.
Any help is appreciated.
Edit: I basically want to run the "-p" command to all other viewports on different layouts.
ВeekeeCZ
Try this... it will PAN from point 0,0,0 to a point by your specification.... 2,0 ??
Spoiler
(defun c:PanAllVPs (/ pt oCTAB en vp i ss vp)
  (if (setq pt (getpoint "\nSpecify displacement point: "))
    (progn
      (setq oCTAB (getvar 'CTAB))
      (foreach x (layoutlist)
	(setvar 'CTAB x)
	(command "_.zoom" "_E")
	(if (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 x))))
	  (repeat (setq i (sslength ss))
	    (setq en (entget (ssname ss (setq i (1- i))))
		  vp (cdr (assoc 69 en)))
	    (if (> vp 1)
	      (progn
		(command "_.mspace")
		(setvar 'CVPORT vp)
		(command "_.PAN" '(0 0 0) pt)))))
	(command "_.pspace"))
      (setvar 'CTAB oCTAB)))
  (princ)
It process all the layouts and all VP. If you want to protect same of them, lock them.
Thanks to @hmsilva for the core loop.
This is absolutely amazing! Its going to make everything so much easier and faster.
I appreciate your quick response and the time you spent in helping me out. Thanks again.
mc5fan
How do you use that? I don't understand.
L.M.
Lee M.
cadffm
Please stop with spam.
Set your setup in PAGESETUP or PLOTdialog and apply to pagesetup.
If you dont write what you are looking for we can not help!
The offset is reachable in both dialog.
PLOTOFFSET is for relativ to printarea or paperborder, look into F1
If you only searching for the white paper position in layout, set your want pagesetup and it will follow your given printing area.
Sebastian
mc5fan
Spam? Really? How about less fluff from your end? My Manager explained it quick and simple with no attempt to throw insults. Maybe next time.
Lee M.
3dwannab
Another similar thread here. I posted one that can work with locked viewports based on a modification of marko_ribars program.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/pan-all-viewports-in-selected-layout...
