Shift the overlapping text to right side
arshadmirza786
Message 1 of 9
arshadmirza786
Attached PRL.lsp help to write the value of X,Y at desired place problem is when a line is in vertical steps, the 2 values are overlapped and has a labour work to shift the each value to left or right
Can any one help to improve, the value overlapping be shifted as per text height to left or right for improving readability thanks
Replies (8)
Message 2 of 9
CADaSchtroumpf
Try to replace function WRITE-VERTICES by this
(defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR)
(setq httt "0.1")
(setq gptx (getpoint "\nBasepoint for X axis: "))
(setq gpty (getpoint "\nBasepoint for Y axis: "))
(setvar "lastpoint" gptx)
   (foreach ITEM NEWVLIST
      (setq XSTR (rtos (nth 0 ITEM) 2 2)
            YSTR (rtos (nth 1 ITEM) 2 3)
            ZSTR (rtos (nth 2 ITEM) 2 3)
            STR  (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR) ;_ strcat
      ) ; setq
;      (write-line STR F1)
(if (> (+(atof xstr)(/ (atof httt) 2.0)) (+ (car (getvar "lastpoint")) (atof httt)))
  (progn
    (command "_text" (list (+(atof xstr)(/ (atof httt) 2.0)) (cadr gptx)) httt "90" (strcat xstr))
    (command "_text" (list (+(atof xstr)(/ (atof httt) 2.0)) (cadr gpty)) httt "90" (strcat ystr))
    (setvar "lastpoint" (list (+(atof xstr)(/ (atof httt) 2.0)) (cadr gptx)))
  (progn
    (command "_text" (list (+ (car (getvar "lastpoint")) (atof httt)) (cadr gptx)) httt "90" (strcat xstr))
    (command "_text" (list (+ (car (getvar "lastpoint"))) (cadr gpty)) httt "90" (strcat ystr))
    (setvar "lastpoint" (list (+ (car (getvar "lastpoint")) (atof httt)) (cadr gptx)))
   ) ; foreach
) ; write-vertices
PS: I have change the variable httt to "0.1" (before "1.75") to according at your drawing
Message 3 of 9
arshadmirza786
1-    Sorry it start "Text" command after loading the lisp,          afterword does not start with "PRL" may be copy               paste error
'2-    text height =(3x scale of model) in my case 3x750             =2.25 instead of 0.1 that's better
Message 4 of 9
calderg1000
Regards  @arshadmirza786
In the PRL2 file, you have some other lines that I have commented on. Also add "none" in the Text command in case you have Osnap activated.
I suppose you have in mind to activate F11, before executing the routine
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 5 of 9
CADaSchtroumpf
You have make a bad copy-paste
Message 6 of 9
arshadmirza786
 @calderg1000
Thank you foe helping
1- X value read from WCS 0,0,0 instead of Start of Line X = 0
2- Text spacing is double the text height, Pls make it single space
Message 7 of 9
calderg1000
Hello @arshadmirza786
Make the change indicated on the highlighted line. The other change I do not interpret well, if possible attach an image as it should be.
Regards.
Carlos Calderon G
Message 8 of 9
CADaSchtroumpf
Change (without bad copy-paste) 😉 the function WRITE-VERTICES
(setq httt "2.25")
(setvar "lastpoint" (car NEWVLIST))
      ) ; setq
(if (> (+ (car (getvar "lastpoint")) (atof httt)) (atof xstr))
  (setvar "lastpoint" (list (atof xstr) (cadr gptx)))
    (command "_text" "_none" (list (car (getvar "lastpoint")) (cadr gptx)) httt "90" (strcat xstr))
    (command "_text" "_none" (list (car (getvar "lastpoint")) (cadr gpty)) httt "90" (strcat ystr))
   ) ; foreach
) ; write-vertices
Message 9 of 9
arshadmirza786
@calderg1000
Next dwg is where we start the original PRL
Pls advise
