Sheet List Tables
Sheet List Tables
Sheet List Tables
I have two different sheet sets, one is set up for grading plans and other schematic drawings (Sheet Set A) , the other sheet set is for plan/profile drawings (Sheet Set B).
I created a sheet list table in Sheet Set A on the index page to include all the sheets from the sheet set, when I click "Update Table Data Links" after I make a title or number change to a sheet it updates with no problem. Also, I can press "CTRL+Left click" and it automatically navigates to the drawing I selected.
My other sheet list table from Sheet Set B includes all the plan/profile drawings. The sheet list table in B is a copy from Sheet Set A plus a column for stations so both tables are basically the same. In Sheet Set B the sheet list table updates with no problem as well the "CTRL+Left click" works fine. I copied the sheet list table from Sheet Set B to Sheet Set A and it loses its ability to "Update Table Data Links", the error message pops up saying:
2 object(s) could not be updated.
0 object(s) updated successfully.
I am still able to open drawings from Sheet Set B with "CTRL+Left click" in the sheet list table while I am in the Sheet Set A drawing.
Is there anyway I can get my sheet list table from Sheet Set B to update in Sheet Set A?
dbroad
I don't believe that copying a sheet table from one set to another is supported.  Each sheet set table should reside in a layout in its own sheet set.  Sorry but those are the limitations.
Architect, Registered NC, VA, SC, & GA.
Is there a way to purge an existing Sheet List Table on a layout (if it appears to be broken), so that I can make one again from scratch on that layout?
dbroad
I think you can just delete and recreate.  I don't believe sheet list tables automatically update anyway.
