Sheet Count Attribute across different dwg files
renaldy_wibisonoSHQ64
Message 1 of 14
Hello!
I achieved the totallayout count within a dwg file by using this code :
(defun TotalSheetNumber (a r)
(setq totalLayouts (length (layoutlist)))
(vlr-command-reactor nil '((:vlr-commandWillStart . TotalSheetNumber)))
The Problem is, i just realised that i would have to count also sheets from other dwg drawings.
I'm not sure if this would work, but i was thinking about if this LISP code will work if i set up a Sheet set which includes all the dwg documents
Replies (13)
Message 2 of 14
Moshe-A
@renaldy_wibisonoSHQ64  hi,
(layoutlist) function works only on the current active dwg
even if you work with SSM, at each time only 1 dwg is currently active.
So to get what you want, you will need hold all files open and iterate
you install TotalSheetNumber function on (vlr-command-reactor) for :vlr-commandWillStart
do you really want it to run at each command invocation?
Moshe
Message 3 of 14
pbejse
  • Opened drawings?
  • I take it its more than one layout tab per drawing?
  • Do you want this to include subfolder?
Message 4 of 14
so what should i do?
for example i have 3 dwg files,
A has 12 Layouts, B has 14 Layouts and C has 8
so in each of those titleblocks in each layout, the total sheet number should read 34, across all files
Message 5 of 14
what is a subfolder?
Message 6 of 14
daniel_cadext
You could us an API with access to the layout manager, ARX, .NET pr Python
from pyrx_imp import Rx, Ge, Gi, Db, Ap, Ed
import traceback
def getLayoutCount(db):
    try:
        lman = Db.LayoutManager()
        token = lman.setupForLayouts(db)
        print("Num Layouts = {}: ", lman.countLayouts(db))
        print("Layouts info = {}: ", lman.getLayouts(db))
    finally:
        lman.clearSetupForLayouts(token)
def processDb(path):
    sideDb = Db.Database(False, True)
    sideDb.readDwgFile(path)
    sideDb.closeInput(True)
    getLayoutCount(sideDb)
def PyRxCmd_doit():
    try:
        path = "E:\\Source.dwg"
        processDb(path)
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 7 of 14
Sea-Haven
Sub folder start at C:
Then C:\Cad dwg
Then C:\Cad dwg\projects
Then C:\Cad dwg\projects\2024-123
Then C:\Cad dwg\projects\2024-123\images
Then C:\Cad dwg\projects\2024-123\otherstuff
Then C:\Cad dwg\projects\2024-123\otherstuff\notes 4 subfolders !
Message 8 of 14
pbejse
A folder contained within another folder.
Message 9 of 14
pbejse
(defun C:HML ( / totalLayouts dwgFiles odbx layoutOndwgFile); HowManyLayouts
(if (And
      (setq folder (acet-ui-pickdir
		   "Select Project Folder"
		   (if folder folder (getvar 'dwgprefix)
      	(setq dwgFiles (vl-directory-files folder "*.dwg" 1 )))
  (progn
    (if (< (atoi (substr (getvar "ACADVER") 1 2)) 16)
	(setq odbx (vlax-get-or-create-object "ObjectDBX.AxDbDocument"))
		     (strcat "ObjectDBX.AxDbDocument."
  (foreach itm dwgFiles
	(if  (not (vl-catch-all-error-p
			 (vl-Catch-All-Apply
			   '(lambda () (vla-open odbx (strcat folder "\\"itm))
	   (progn
	     (setq layoutOndwgFile (vla-get-count (vla-get-layouts odbx)))
	     (setq totalLayouts (cons (list itm (1- layoutOndwgFile )) totalLayouts))
	     (print (car totalLayouts))
	   (print (strcat "Odbx connection no available with file :\n"
     (vlax-release-object odbx)
     (print (strcat "Total number of layouts from " (itoa (length totalLayouts)) " drawing file(s): " (itoa (apply '+ (mapcar 'cadr totalLayouts)))))
  (print "\No drawing file(s) found")
  (princ)
Message 10 of 14
Sea-Haven
What about part 2 ? You have asked for total sheet number, but what about "Sheet X of Y" if you add or remove a layout from A are the individual sheet numbers updated ? dwgB needs +1 dwgC +1 and so on.
To work need the dwg's selected in an order of numbering. For me a dcl with add dwg number order. The excellent code by PBE could possibly be added to include sheet numbering. Something start with something like this.
You could store the dwg names in all dwgs using LDATA. So in any dwg from a group update the sheet number and total sheets.
Just a comment we for 99% of the time only worked with one dwg, but does not Sheet set manager support sheet number ? We did not use it.
Message 11 of 14
Thank you for the solution!
I would love to understand this code, if you have the time to explain this, i would very much appreciate it!
Message 12 of 14
pbejse
Did the solution worked and helped you with what you need @renaldy_wibisonoSHQ64 ?   then you know what to do next right?
I would love to, all you need now is to purchase a ticket, board a plane and fly out here so we can have a beer and at the same time i'll explain the code to you 🙂
Message 13 of 14
after studying this code ive come to somewhat of an understanding (or more like assumptions)-
So the function is called C:HML (How Many Layouts)  with arguments 'totalLayouts' 'dwgFiles' 'obdx' and 'layoutOndwgFile'
>with the first (And   ) command, we get the directory that contains the project's dwg files "folder" and create a lists of all the dwg files "dwgFiles" of the poject.
> if the autocad version is earlier than version 16, we have to first set obdx to "ObjectDBX.AxDbDocument", "ACADVER"
> for each element in the 'dwgFiles' list, we ;
     > first verify wether there is any errors while calling the individual files,
     > then we return the value of the layout count for the files, and set this as 'LayoutOndwgFile'
     > then insert this value in the first element of the list 'totalLayouts'
> repeat for all files in 'dwgFiles' and therefore, 'totalLayouts' will be a list containing all the Layout counts of each file
> print the value (integer to array) the sum of all the elements of "totalLayouts' (?)
few questions :
1) i dont understand this if loop in the setq command ;
(setq folder (acet-ui-pickdir (if folder folder (getvar 'dwgprefix))))
so you set a variable folder, by first determining if the not-yet-defined variable folder has the dwgprefix?
2) in (setq dwgFiles (vl-directory-files folder ".dwg" 1)) , what is the 1 for?
3)why do we have to add the ACADVER if the AutoCAD version is earlier than 16? i assume it has to do with the format but idk
4) in line 31;
(setq totalLayouts (cons (list itm ( 1- LayoutOndwgFile )) totalLayouts))
a) itm is item? as in an element in a list?
b) you used a decrement of 1 in the LayoutOndwgFile - is this because the model is counted as a layout and therefore has to be substracted?
c) again question about the syntax : you set 'totalLayouts' as a list of itself ( which in the first loop, should not have been defined yet) - is this because, it is a foreach loop and therefore, in the first iteration where it has not been defined yet, it will return as an empty list? and we fill it from there with the foreach loop?
5) in the line 41 ;
(print.....(itoa (apply '+ (mapcar 'cadr totalLayouts))
i thoght cadr returns the second element of the list TotalLayouts? i dont understand this line of code
Message 14 of 14
pbejse
few questions :
DWGPREFIX is a system variable as you probably already know,  at initial run where variable folder is null , the program will use the value stored from that system variable DWGPREFIX as the path argument for the function acet-ui-pickdir
On the next run the value that was assigned to folder the first run will now be the default, as we did NOT declare that variable as local.  ( / totalLayouts dwgFiles odbx layoutOndwgFile).
vl-directory-files (AutoLISP)  <--- 1-- List files only
Yes, you can say that.
itm is the Variable that each element in the list will be assigned to at every loop of foreach
in this case, its the name of drawing currently being process
Correct
That is the beauty of using the function cons, <-- read about them
5) in the line 41 ;
Read these and get back to us if you having a hard time understanding them
apply  / mapcar  / lambda
