Setting the DCL ID
Setting the DCL ID
mgorecki
Message 1 of 11
Setting the DCL ID
mgorecki
I am currently using 2 lines to set the DCL ID.  One line points to the local folder and I use it when testing.  The other just uses the DCL filename and is used when creating the .VLX.
;(setq dcl_id (load_dialog "C:\\MyPrograms\\MyLspFolder\\MyLsp.dcl")) ;use when testing
 (setq dcl_id (load_dialog "MyLsp.dcl")) ;use when creating a VLX
The code and DCL are located on my local drive, but the .VLX is located on the network.  That's why I use two different lines.  I comment one out when testing or creating the .VLX.
I'm sure there a better way to do this.  Is it as simple as setting trusted locations?
Replies (10)
Message 2 of 11
paullimapa
AutoCAD needs to know where your MyLsp.dcl is located.
Your code currently does not show this. Only way that this works is if your MyLsp.dcl is located in one of the folders defined in your AutoCAD Options> Files> Support File Search Path
Paul Li
IT Specialist
@The Office
Message 3 of 11
mgorecki
Yeah, that's what I was thinking.  It only knows (when testing) because I gave it the entire path.  So, for every project that has DCL's, I would need to supply that path to the Support File Search Path.
Message 4 of 11
paullimapa
Or just include in your lisp to write the dcl code on the fly to temp folder then your lisp code will design that as the path to load the dcl. Then when lisp code completes also include function to delete the generated dcl
Paul Li
IT Specialist
@The Office
Message 5 of 11
mgorecki
Yes, I've done that before for more simple DCL files, but some of these are pretty complex.  Plus, I like to view the DCL as I'm creating it with Tools > Interface Tools > Preview DCL in Editor so I can make it look "just right". 😊
Thank you for your input, I just set the path and tried it, and it worked just fine.
Message 6 of 11
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 11
Sea-Haven
Try this great program by RLX. Writes dcl to lsp.
Message 8 of 11
-didier-
Bonjour @mgorecki
When you create the VLX, you can include the DCL in the "application".
The there in just ONE file vlx who contains the lsp AND the DCL.
Then the second line is enough.
Have you tried ?
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 9 of 11
mgorecki
Hello Didier,
Thanks for your thoughts.  All of my programs are made into VLX, the problem was testing.  I would use the first line while testing, then when I was ready to create the VLX, I would comment that out and use the second line.
But now I add the current work folder into my "Support File Search Path", so I only have to use the second line.
Message 10 of 11
mgorecki
Hi Sea-Haven,
Wow, I'll have to study that one.  Thank you for sending that to me.
How, exactly, does one use it?
Message 11 of 11
paullimapa
we all have our favorites to convert dcl to lsp like this similar one attached
Paul Li
IT Specialist
@The Office
