(setq p1 (getpoint "\nPick the point on the screen for the first corner:") )
(princ p1)
(setq p3 (getpoint "\nPick the point  on the screen for the second corner:") )
(princ p3)
Hi!
I have a question regarding these commands
1) When I run this part of the script
The coordinates of entered point are printed.
How do I avoid it?
2) When I run the entire script
The coordinates of the first point are printed once
and the coordinates of the second point are printed twice
 Why it works in this way?
Thanks!
Ajilal.Vijayan
1. LISP will always return the result of last function.
To avoid this, you can use (princ) at the end of each function.
Click the +sign to see the Code
Spoiler
(princ)
Read the Display message functions in LISP.
2.The coordinates of first point are printed twice because of (getpoint) function and (princ) function.
Hope this helps.
Thanks!
ВeekeeCZ
If you trying to get window... then use (getcorner) instead od (getpoint). the result is the same, but you'll see a window on the screen.
(setq p3 (getcorner p1 "\nPick the point on the screen for the second corner:"))
(princ)
Thanks!
You need to realize that each function returns something. Usually can't see it.... but last one. That's why we usually use (princ) at the end - to print nothing.
But this principle is very important to understand....
(setq pt1 (getpoint))
(setq pt2 pr1)
is same as...
(setq pt2 (setq pt1 (getpoint)))
Thanks a lot!
