SetCellBackgroundColor
john.uhden
Mentor Mentor
john.uhden
Is there a way to use this method on an AutoCAD Table cell using an AutoCAD index color, like 254?
John F. Uhden
paullimapa
you'll have to use the method to convert the aci to acCmColor like this example:
https://www.cadtutor.net/forum/topic/66724-how-do-you-fill-a-table-with-a-color/?do=findComment&comm...
Paul Li
IT Specialist
@The Office
komondormrex
check this
Set Table Cell Color
Sea-Haven
Maybe this
(setq acCol (vla-get-truecolor objtable))
(vla-put-colormethod acCol acColorMethodByACI)
(vla-put-colorindex acCol col)
(vla-setcellbackgroundcolornone objtable 1 0 :vlax-false)
(vla-setcellbackgroundcolor objtable 1 0 accol)
(vlax-release-object acCol)
john.uhden
@Sea-Haven ,
I don't understand that mumbo jumbo.
Why didn't I think of this before?...
I'm gonna format one cell manually then apply its result to the targets.
(I hope it works.)
John F. Uhden
Sea-Haven
Hi John should have posted row column example.
(vla-setcellbackgroundcolornone objtable row column :vlax-false)
(vla-setcellbackgroundcolor objtable row column accol)
