I need a lisp to put into my Startup Suite that will set views to all (paperspace) layouts, see image. Thanks.
AutoCAD 2017
Solved by Ranjit_Singh1. Go to Solution.
The height and width of your view will depend on several factors and would not be exactly 3'-3" and 6'-1". For instance, where is you property window located, what size it is, how big is the prompt line etc. You can however set the center and the zoom extents.
(defun c:somefunc ( / ) (command "._zoom" '(-16.5 32.5 0.0) '(56.5 -6.5 0.0)))
EDITED: For all layouts
(defun c:somefunc ( / curtab)
(setq curtab (getvar 'ctab))
(foreach i (layoutlist)
(setvar 'ctab i)
(setvar 'ctab curtab))
This should get you started.
(vl-cmdf "._Zoom" "_C" "20,13" "39")
