Set View To All Layouts
wispoxy
Advisor Advisor
wispoxy
I need a lisp to put into my Startup Suite that will set views to all (paperspace) layouts, see image. Thanks.
AutoCAD 2017
Ranjit_Singh
The height and width of your view will depend on several factors and would not be exactly 3'-3" and 6'-1". For instance, where is you property window located, what size it is, how big is the prompt line etc. You can however set the center and the zoom extents.
(defun c:somefunc ( / )
(command "._zoom" '(-16.5 32.5 0.0) '(56.5 -6.5 0.0)))
EDITED: For all layouts
(defun c:somefunc ( / curtab)
(setq curtab (getvar 'ctab))
(foreach i (layoutlist)
(setvar 'ctab i)
(setvar 'ctab curtab))
wispoxy
I'll test it out and share results.
rkmcswain
This should get you started.
(vl-cmdf "._Zoom" "_C" "20,13" "39")
wispoxy
Exactly what I needed. Thank you so much.  🙂
Ranjit_Singh
You are welcome Smiley Very Happy
