Set value to variable, VL ...
carlos_m_gil_p
carlos_m_gil_p
Hello boys how are you.
I am trying to set a variable with VL functions, but it gives me an error.
; error: Automation Error. Error setting system variable
Why does this happen and how can I correct it?
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-variant-value (vla-GetVariable doc "3dosmode"))
(vla-SetVariable doc "3dosmode" 3)
Thanks a lot.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
john.uhden
Why struggle unnecessarily?  Just use getvar and setvar.
John F. Uhden
hak_vz
If you strictly use visual lisp than  use this.
Visual lisp functions need to be feed with adequate data type i.e. variants. Google or lookup in help vlax-make-variant
(setq old_3dosmode (vlax-variant-value (vla-GetVariable doc "3dosmode")))
(setq new_val (vlax-make-variant 3 vlax-vbInteger))
(vla-SetVariable doc "3dosmode" new_val)
Or simply
(setvar '3dosmode 3)
Miljenko Hatlak
carlos_m_gil_p
Hi thanks.
I will be more pending.
I will always forecast the data to avoid errors.
AutoCAD 2026
carlos_m_gil_p
Hi @john.uhden , I'm just trying to get a better understanding of these functions and how they work.
AutoCAD 2026
john.uhden
Learning is a great thing.  Attaboy!
John F. Uhden
